- Jul 16, 2020
- Los Angeles
- Franklin
- c10
DC-3
Wow that brings back memories of my childhood, when on a quiet night, you could hear the cars rusting where they were parked!You must be registered for see images attachYou must be registered for see images attach
Forgot to update. I had an OK trip, but I am really lucky because the rust on my gmt800 factory hitch was fatal and i just made it home before it failed completely. The thing about it is that the chain hooks are attached to the same point, it would have been a runaway trailer!You must be registered for see images attachYou must be registered for see images attachYou must be registered for see images attach
Im not too worried, but i am bummed. Im just glad it happened with the least dangerous/nothing to lose load possible, and it wasnt stressed on the road because of weight. The bumper I knew was getting bad, it was squishy to step on, but the trailer hitch was hidden just behind it
I am going to replace the bumper and the hitch, curt and others make solid square tubing aftermarket ones, the oem one is defintiely a weight reduction type situation but if i found a good one from gmt800-900 i could use it. I also could use a gmt800-900 bumper Im pretty sure.
when I do that, Im gonna do the rear cross member which is large but its sold new and its the spare tire crossmember AND it contains the driver side shock-mount
TO do so requires lifting the bed up, but thats a good time to stop rust on the frame and the springs and axle, gonna shoot for next summer to do this
it would be kinda wasteful to go bring one of those hereWow that brings back memories of my childhood, when on a quiet night, you could hear the cars rusting where they were parked!
Thank god more people don’t come out west to buy used cars, because it’s worth it! But there would be no used cars left for us locals here!
You have waste oil, get a hudson sprayer and coat the undercarriageit would be kinda wasteful to go bring one of those here
it would be murder ;(
Unlesss you kept up on it, Wintertime its truly not hard to keep vehicles clean here you jsut gotta use a car wash at least weekly
yes, ive been thinking of that. is that something youd want to cut it with anything or just straight out of the barrel?You have waste oil, get a hudson sprayer and coat the undercarriage
FYI you are supposed to crisscross the safety chains,under tge trailer tongue. Trailer right side chain to vehicle left side and vice versa. 2 things going on there, if the hitch comes off the ball the trailer tongue will land in the X of the chains instead of on the highway, and when you turn the chains stay more equidistant to the truck.You must be registered for see images attachYou must be registered for see images attach
I had issues with the chains binding on the ball hitch when crossed (I do know that, thank you) the chains were adjusted to my f150 which has the hooks in a different spot, I Need to give it slack for this setup, I just didnt have the time. But if I had used a less of a drop hitch (but would have slanted my trailer way too much upwardss) it would have workedFYI you are supposed to crisscross the safety chains trailer right side chain to vehicle left side and vice versa. 2 things going on there, if the hitch comes off the ball the trailer tongue will land in the X of the chains instead of on the highway, and when you turn the chains stay more equidistant to the truck.
For when I do things proper yeah that would be goodPOR 15?
