383 Stroker
AustinDube
1976 Chevy K10 Custom Deluxe
Maine
Austin
K10 Custom Deluxe
5.7L 350
Wondering about getting a stroker kit but my only consern is the balancing. The kit i found is already pre balanced but its externally balanced with a flex plate in the kit, I have a manual flywheel but found this bracket on ebay as a counter weight
http://www.ebay.com/itm/191450583552
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
I'd look for an internally balanced set up or take what you got or get to a machine shop and have it balanced. Mallory Isn't cheap but the best way IMHO.
74 Shortbed
Internal is the way to go, but if you're on a budget that plate works good, I used one on a 468 for a few years and buzzed it 7500+ with no problems..
AustinDube
Maine
Austin
K10 Custom Deluxe
5.7L 350
75Monza
Colville, Washington
K30, K20, K20
AustinDube
Maine
Austin
K10 Custom Deluxe
5.7L 350
I asked a seller on ebay and he said he can internally balance it for an extra $125 instead of externally. and also mine is a 2 pc rms and a 4 bolt main 350
gpmorgan
Tupelo Ms.
greg
Make sure you check the clearance on the pan rails and lower cyl bores. Probably need a small base circle cam too.
78silverado
