- Aug 29, 2010
- OKC, OK
- HotRod
- 85 K20 LWB
- Silverado
- 454 - Turbo 400 - 3.73
http://www.summitracing.com/parts/HRS-180305-08/
Im thinking about using this cam i heard howards cams are some of the best
I had a lunati bracket master 2 almost with the same specs i loved the sound of this cam and figure it will sound the same but even better bein a 383
Are you asking cuz you want to get talked into it, or are you asking cuz you want to get talked out of it???
Honestly, I don't like it !!! A few things wrong with it IMO. Now, if you are just wanting something to sound good and mean, then you got it. But I honestly think that will be a ALL SHOW, as in sound, but NO GO. Granted, That's an exaggeration, cuz it will go, but you better have a whole lotta stall cuz it won't make good power in the low end at all. If it was just strip truck, then sure, go for it, but even then, if its a strip truck, find something that will turn some rpm since SBC's love rpm. Get up into a power band range of at least 6000 and better yet to 6500 if you are wanting a top end cam and that is what you chose there.
I'd go with something in the 1500-1800 low side power band range, and up to 5800-6000 rpm and on a 110-112 LCA instead of 108. Lower the LCA the higher the rpm range for torque. The Highter LCA like 110-112 and even 114 are for low end grunt That would be my choice for a potential both street and strip truck.
