Planning my Suburban build - Advice wanted
geocrasher
Northern NV
Ryan
V1500
Your vehicle is setup perfectly for what you've described as your stated purpose. Maybe get some crossover steering into it but beyond that, it sounds like you want to do it for looks. And that's okay. But it's even overkill for what you've stated. I have similar intentions for my rig, and it's on 10 bolts with 31's and a 2" lift lol.
grampsbutler
San Diego, CA
Graham
K10 Suburban
6.2l Diesel
As stated above, I'd definitely lean towards a GM D60. That what I did for my build and couldn't be happier with it. It was a straight bolt in, the brakes are awesome and its as strong. You'd end up spending a lot of time and money modifying a ford D60 to fit. You may also need a driver side drop transfer case if you go that route (more $$ and headaches). The GM D60 is a bit harder to find, and more $$ up front, but it will be worth the time and effort savings.
I have a 6" lift on mine and I run 37" rubber with only minor rubbing at full flex with no fender trimming. You'd probably get away with a 4" lift if you trim your fenders aggressively.
Here is a picture to help you get a visual, and a link to my suburban build.
Domarinolo
