1994 S10 1Ton SAS
78C10BigTen
pennsylvannia
C10 BIG TEN
So, I got the old 10 bolt out, and as I suspected, it was a sloppy ho form my abusing it LOL.
Got the 14 bolt in, that was a real pain. But it's in there now! Rear looks higher than the front, but to the best of my knowledge, it's because the front tires are flat.
I have tubes for those, but I haven't installed them yet.
Either way, the majority of the hard stuff is OVER!!!!
It looks miniscule to the one in front of it lol. But damn im diggin it!!
78C10BigTen
pennsylvannia
C10 BIG TEN
Btw what motor are you using to power that monster?
RecklessWOT
New Hampshire
Kevin
V10 Suburban Silverado
So I changed up the design a little, and after work I roughed out the basical shape of the arm... Whenever I get a little time again this weekend, I will finish it.
Holy chatter Batman!
And yeah, this. I mean, I got a lot of respect for the 4.3 Vortec, but I doubt she'll cut it in this case. Tell me you got a SBC lined up for it?
Either way, that thing is lookin badass. Can't wait to see it all said and done (with videos of it tearing **** up too hah)
78C10BigTen
pennsylvannia
C10 BIG TEN
I would hope he woulda already put in the sbc since now the engine bay is 6' in the air lol
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
Its not chatter, that's a high SFM 1" cutter running at 150 ipm just ripping steel off of a 2x5 block.
No sbc lined up, sorry guys, I have one sitting right now I could drop in. That 4.3 has sentimental value to me, me and dad built that motor. I'd take a guess to say it makes a respectable 2-250 HP n/a. Higher compression with bigger cylinders and a little different cam.
Might not be sbc power, but I'm not canning it until It quits, then I'll swap in a 5.3 or 5.7 vortec in.
Vbb199
Salisbury NC
Vince
No sir, you're thinking of the k5.
Im a 6 foot 5 tall guy and the hood is just under the top of my head
RecklessWOT
New Hampshire
Kevin
Insert cutter with thru coolant or something? A feed rate of 150 is CRAZY! What kind of spindle speed you using? I mill mostly stainless steel and high nickle alloys all day long, occasionally some SA105 carbon is about the softest stuff I'll ever see in this shop (man I miss working with aluminum and brass lol). I'm the ballsy guy in the shop because I push my solid carbide endmills to like F5.0 when going full width of cut. How does that **** not explode at 150? Hah I see you're making some proper blue chips though. I must know what kind of tools you're using, that is freaking awesome.
Realistically though, 200-250hp is basically SBC power. Hell, what's a 305 make, 145hp? Hah I'm pretty sure my TBI 350 only makes 210hp so I guess it's cool. My S10s had plenty of power but they were only turning 31s, not 40s. Either way, besides the axles that's a light little truck, with proper gearing yeah I suppose you're right it should be good enough
Vbb199
Salisbury NC
Vince
1500 rpm, 150 ipm, that'd just CRS I'm making thr arm out of... But truth be told... I was using toolsteel speeds and feeds because that's what we mainly machine for tools A2, D2, S7...
.... CRS it can be ran much much harder. HELL! 1500/150 is the bottom of what it can be run at on toolsteel.
It's 3 flute insert cutter, no coolant. The coolant breaks down the insrdts faster, but you can run air on it just to keep the tool cool.
It even punishes 58-62 RC toolsteel no problem. It's a bad little mf.
Vbb199
Salisbury NC
Vince
Send me a pm, and I we'll exchange numbers and I'll send you the details of what it is Monday when I'm in the shop @RecklessWOT
Vbb199
Salisbury NC
Vince
It'll clear out a 6.5x6.5 area, 1/4" deep in soft annealed toolsteel in 8min flat.
Somewhat hard to perceive.... Or even maybe grasp... But that's lightyears beyond traditional milling with just a solid carbide 1" cutter.
78C10BigTen
pennsylvannia
C10 BIG TEN
Well hell my 6' ass would be lookin at the bowtie lol
Vbb199
Salisbury NC
Vince
A little perception for you, it's not as big as you might think.
Vbb199
Salisbury NC
Vince
It's a multiport fuel injection 4.3
4.3 gets alot of hate for many reason.... The tbi was a flat turd, and 4.3s that they put in trucks now or was putting in are ****** dogs that make 4cyl power and drink gas like a 8 cyl.
The 4.3 CMFI is generally the "cream of the crop" in these small v6's.
When it was running on 31s with the 3.42s, I could spin the tires with posi if I stomped it, and from first gear if I wound it up to 5800, it was still making power. Not a bad little motor. It killed a couple transmissions and rear ends after the rebuild.
jlyon1006
