1986 k10 getting ls swap exhaust question
bigceyers
cambridge ontario canada
chris
alright i recently got a nice 1986 gmc longbox 4x4
I've got a complete 5.3 vortec ls drive by cable
bought crank spacer and engine plates
so i also have computer and wiring harness
I'm doing a 87 fuel tank and sending unit
so i am lost with exhaust i want headers or manifolds that fit and don't need any reworking i wanna just bolt it up and go
IIRC, Camaro exhaust manifolds.
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
2010-up Camaro, specifically, should fit.
Hooker Cast Iron LS manifolds are a great option.
I believe Trailblazer SS and Buick Rainer V8 manifolds will work as well.
These are generally the best fitting manifolds, but the motor mount adapters you use will always play a role. The Hooker manifolds are the best I've seen for clearance.
In addition, none of these will just "bolt up and go" to your existing exhaust. They will all need to be tied in. Nothing available will just bolt up and fit your existing exhaust.
Camar068
10 yrs Air Force
I'm diggin around for bang/buck mounts. Care to elaborate? LOL "keep searching" is a fine answer as well.
throttle out
Michigan
Sam
5.3 LS
Are you using 700R4??
If so, I used Schoenfield 1302LS1's and they bolted rite up. I chose to move my driver side o2 sensor bung, but could have made it work without.
c20suburban
