Transfer Case Info for OEM Squarebodies
Turbo4whl
Downingtown, PA
Wayne
Yes, it's all still there. Top number is the model, 208 C for Chevy, (or GMC)
Bottom number the ratio, 2.61:1 (low gear)
The middle numbers refer to the assembly; input splines output yokes etc.
LS1FREEK
Sublette, Ks
So I have a 1980, K10 rcsb Silverado, TH350 with lockup, 205 transfer case. Glovebox says it's an "HD" transmission, what will my transfer case input shaft splines be? I wanting to convert to a 6L80e transmission.
In the post it isn't clear but looks to be 27 spline:
"27 spline (from Turbo 350 applications): (1971-79) The units supplied with a T350 automatic have a 27 spline male input shaft.
32 spline SHORT (appx 2" stickout)
32 spl LONG a(appx 3-5/8" stickout)
These are both from (Turbo 400 applications) (also some SM465 86-up may have used a 32 spl input.) We have seen both a short (about 2.0" stickout) and long (3-5/8"" stickout) versions of this gear. The adapter casting in both cases is 4-3/8" long. With the short input, the trans will have an output shaft that sticks out of the main case of the trans appx 4" With the Long input, the trans will have a shorter mainshaft: Sticks out of the main case about 2.5"
1979 to 1985 GM NP205: 8 bolt "racetrack" bolt pattern:
During these years, the GM NP205 showed up behind Turbo 400 and SM465 Transmissions in 1 Ton trucks only.. 1/2 and 3/4 T trucks began to be supplied with the NP208 instead. SM465 units will still typically use the 10 spline input. Turbo 400 units have the stout 32 spline female input (in most cases the short 32 spl input, about 1.5-2.0" stickout) however still uses the 8 bolt "racetrack" bolt pattern."
nvrenuf
Mobile, Al.
@LS1FREEK your tcase will have a 27 spline input shaft.
WRW86
Alberta, Canada
Warren
K2500
Np205
NP205
The NP205 gear driven transfer case is considered by many to be the king of bulletproof. It was supplied in many GM, Ford, International and Dodge full-size trucks.
GM NP205
Note 8 bolt "racetrack" bolt pattern on early Chevy. Late Chevy will have the six bolt circular pattern, similar to the Ford, except the Chevy unit will have the front output yoke on the passenger side, like the early Chevy.
Bolt Pattern:
All GM NP205 cases 1971-1985 had a 8 bolt "racetrack" bolt pattern
All GM NP205 Cases 1986-up had a 6 bolt circular bolt pattern
Input Spline: GM Used four different input shaft configurations on these cases.
10 spline (from SM465 Applications): (1971-85) The most common were units supplied with a 4 speed which typically had a 10 spline male input shaft.
1986 and Later GM NP205: 6 Bolt circular bolt pattern:
At this point GM updated the unit to use the same 6 bolt circular bolt pattern used on the NP208, and all subsequent GM full size 4x4 truck applications. All of them are the 32 spline female input, although those we have seen are the long (about 3.5" stickout) 32 spl input.
Front Output
GM used two front output shaft configurations, one had a spline count of 10, the other was a 30 spline. 10 splines came before 1977 (roughly) 30 spline shafts came after 1977 (again, roughly). One quick way to tell them apart is by the fact that 10 splines came with a 1310 series yoke output, capable of accepting a CV or yoke driveshaft. 30 spline shafts came with the flat flange on the output, capable of accepting the GM 3R series CV joint.
The 10 spline output will accept the stock 1310; Or a separately purchased 1330 or 1350 Spicer u-joint yoke, and the 1310 CV yoke. The 30 spline flange will accept the 1330 or 1350 CV joints.
Rear Output
The most popular version Is a 32 spline shaft / fixed yoke and will accept a 1310, 1330, or 1350 u-joint yoke, and the 1310 CV yoke.
Some were slip yoke, with a longer tailhousing.
NP205 Pics
Round Pattern 32 Spline w/ Long Female Input:
Racetrack Pattern 32 Spline w/ Short Input Female Input:
attachment.php
Racetrack Pattern 27 Spline w/ Male Input (Used for Th350 and can be adapted to 700r4 also)
attachment.php
The 6 bolt round pattern started in 1985, not 1986.
I believe you're right about that. I'm certain that was a copy and paste of info so it's certainly subject to be off a bit. It's also possible, some of the earlier 85's might still be racetrack. Not as common in light duty, but very common in Medium and Heavy duty, they'll use up what's on the assembly line and run it into the next year model. I see it on medium duty quite often. Many left overs get tossed onto Medium Duty trucks.
WRW86
Alberta, Canada
Warren
K2500
I finished replacing gaskets and seals on my 85 round pattern NP205 using one of the many "universal" kits that supposedly fits all models from inception to 1991, and found that the gaskets for the input seal housing and adapter to case were the wrong size. The kit I used was from USA Standard Gear #ZTTSK205
The only kit that specified 85-91 GM 32 spline was from Torque King 4x4 (TK2052), but it is unclear as to whether it would have the correct gaskets, but at 3 times the price of the others, I didn't find out.
The rubber yoke star gasket for the 30 spline front output is not available, so I re-used my old one with a little help from some RTV. I bought some gasket material to make the other 2 gaskets that wouldn't fit.
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
EDIT: never really came across auto locking hubs. Now I know...
I hope this has a 700r4. I asked for a picture of the SPID to learn more. It's a diesel, so that should be a pretty good setup for MPG after returning it to stock height and putting milder tires on it.
Original Post:
This is a picture of a burb we are looking at. It’s an 83, but the hubs appear to indicate that it’s full-time 4wd:
I thought the 203 ended in 79. Are there other full-time cases, or is there something not adding up here? Do people install drive slugs on 208/205 equipped trucks?
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
The later 205's have a "big" input bearing. The earlier 205's have a smaller input bearing. Off-road design has a lot of info about 205's. I might have to post it here.
I got my np208 spline seal from torque king. Try looking it up for a dodge version. Most of the dodge and Chevy stuff will swap over. I have a "dodge" flange on my 208 and I'm sure the seal was for the same application.
nvrenuf
Mobile, Al.
To be clear…
The pre ‘85 205’s GM used had 2 different input shaft bearing sizes; 10 & 27 spline were small and the 32 spline is bigger.
All of the ‘85+ GM 205’s had the big bearing because they’re all 32 spline.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
To be clear…
I wasn't very clear lol. Depends on your spline count.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
I'm gonna blow this up real quick here lol. Some pics have a little overlap, but it flows pretty good for the most part. Thanks off-road design!
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
Original Post:
It could be the synchro 205. That's the only other option unless someone messed with it.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
Np203
Loghard
