'73 Chevelle SS Wagon (local find)
JamesSam
VA
Sam
Silverado V10
5.7 L 350 v8
Here's an article about the '73 SS wagon with some pictures. Probably nothing you don't already know, but I thought of you immediately when I saw it.
That article, although rather generalized, is surprisingly lacking in misinformation like most articles on the '73 SS wagon are chock full of.
One weird thing about my wagon... that article, among others and all GM literature I've found state that a rear sway bar is part of the option. But mine does not have one and doesn't appear that it ever did. I've seen incredibly nice survivors online and they have one, but none have had the base 2bbl 350 like mine. I wonder if you had to get the 4bbl or the big block to get the sway bar. Or maybe they just forgot mine at the factory. I'll probably never find out for sure.
HotWheelsBurban
Houston, Texas
Carol
R2500 Suburban
That's interesting....you could be absolutely correct about the sway bar not being available with the base engine. If you could get a look at the big Chevrolet dealership flip book that has all the models, colors and options availability lists, that might give you a better idea. I had one for a '71 but I think I sold it a couple years ago; not sure why we even had it because we never had a '71 Chevy.
The '73 dealer brochure even states that a rear sway bar was part of the package. But I believe those were typically made up before some model year plans were finalized.
HotWheelsBurban
Houston, Texas
Carol
R2500 Suburban
Yes, if you look at the back cover or last pages there are usually comments to that effect.
The car is so rare though, unless you are doing a concours grade restoration, it wouldn't matter. But if you can find the parts for the sway bar installation, and you want one, go for it. In the end, it's your car....do what you want to it.
I actually do have one for it. Will I ever install it? Not likely. It's an excellent cruising car.
Unless of course, the original engine gives up the ghost. At that point then maybe a stock-appearing 383 and other performance goodies could make their way to the car. But that's a bridge I may never have to cross.
keithself68
