Huck's daily - 2005 Z71 crewcab
legopnuematic
Licensed Junk Dealer
MO
Spencer
In my opinion the best way is to have the axle on a stand or fixtured on a bench. That way one can rotate the pinion facing down and gravity assists in holding things, then you can drop the carrier in and not drop an AAM 11.5 carrier and ring gear and have it roll down your arms and legs lol. Also by removing the whole rear (or front), good time to change the u bolts if they have been.
This engine stand fixture works ok, have some gripes with it, but works well enough.
This is what I’d like to build, need to acquire or build a solid table/bench first though. Really nice to establish a solid reference plane to do shock mount/spring perch/knuckle clocking type work to make sure the angles will be correct.
That would definitely be nice to have. I pulled the axle out of my C10 to give to the guy that did its setup. When I dropped it off he was like “where’s the truck? I like to do them in the vehicle”. :shrug:
I’m a workbench kinda guy, if I had a fixture/table, I’d definitely rather do it that way
legopnuematic
MO
Spencer
I’m of the same mind, certainly can do it under the vehicle, with or without a lift, but having it out is just my personal preference. Now, doing this kind of work isn’t what keeps the lights on for me, so trying to make time and $$ doing the work, I can see why doing it under the vehicle is attractive for some, or just the way to make the numbers work.
Now, both regears I’ve done have been more inline with a total overhaul, clean and paint the housing, outer axle seals, outer wheel bearings (semi floaters), the gears and limited slip install of course. On the 14b sf all new perches and shock mounts and brake caliper brackets were welded on. A little different than just a limited slip install, or regear.
That, and it takes less space in my shop to have axle on its own, than having the whole vehicle it belongs to, if it isn’t my own.
legopnuematic
MO
Spencer
And I have the ability to hit my head on everything it seems, mitigating overhead obstacles is a help too…
Catbox
Peter
C20 Silverado Camper Special
Just for another set of pictures to look at, this is what my rear end guy sent for pictures of my Suburbans new gear set.
All finished and ready to go.
It has been 4 years now and no issues.
Thanks! I've learned alot just from looking at other people's pictures. I joined a "Gear Install Technical Group" on FB and between the help I got on my post and reading other's posts about their 10-bolts have helped alot. I also found a bunch of posts from other people having similar struggles with this brand of gears I got (USA Standard). So I bit the bullet after more research and ordered up some Revolution branded gears. The guy that started this business has worked in the gear and axle world for many, many years and worked for some of the best brands. So he had all the contacts and went out on his own sourcing from the best manufacturing plants supposedly. Apparently China and Korea are the only sources for ring and pinions with Korea being MUCH better quality. We'll see but everything I've read online, everybody raves about them, couldn't find a single bad review.
I also decided to step down to a 4.56 ratio instead of sticking with 4.88. The more I thought about it and played with the gear calculators, the less I liked the idea of 4.88s, even with 35s.
The gears showed up last night, packaged very well. Was hoping to get the truck torn down today after work but it's FARGING COLD in our warehouse right now. It's supposed to be 10* warmer tomorrow so I think I'm gonna wait till then to tear it apart and then I'll come up Sunday to start playing with setups
The machining looks MUCH better on these. The pinion is a work of art compared to the USA Standard one
These also came with directions/tips/adjustment tricks and specs. The others had nothing lol
legopnuematic
MO
Spencer
Are those two cut or five cut?
They look to be very nice.
They're 2 cut. They're definitely quite a bit nicer, I hope this solves my issues. But at the same time, I'm glad I went through them so I learned and it's good I learned on a ****** gearset IMO
Got the new Revolution gears in and got everything torn down last Friday. Unfortunately I found one of the carrier bearing races had some scoring in it so had to wait on another master overhaul kit to come in. Finally got that in and started working on getting jt back together today after work
Squeaky clean housing and tubes
Pressed in the new pinion races, threw the factory .036 pinion shim on it and then for the next 4hrs struggled to get the backlash in spec lol
But FINALLY!!! I have a legible pattern!! So much better than the previous set!
Hopefully you can drive it soon, you've been through it with this!
You ain't kidding lol. I'm gonna run a few more patterns today/tomorrow (or maybe just one more if it fights me like it did yesterday lol), get some opinions over the next couple days and hopefully button it up and drive it Sunday/Monday
Here's some of the damage I found taking the old stuff out. Vertical and horizontal scoring on the pass side race, nothing on the driver's side shockingly.
Also 2 of the ring gear bolts got fubar'd coming back out
And quite a bit of fuzz on the magnet. That wasn't there the other 2 times I drove it, something was REALLY not happy that last drive
BillB
