Why doesn't anyone use the Chevy "Connect & Cruise" packages?
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
The biggest issue with the connect and cruise kit is that the GM ECU used in it has no aftermarket support or tunability. So if you change anything in the future, it is completely locked out. Factory ECU's can be tuned easily with HP tuners or EFIlive
Nawwwwww
once upon a time that was the case,
Knot-Kno-Mo
:bleh:
Side note, did you message me recently to make sure i wasnt dead? Someone from oregon did
WFO
Texas Panhandle
That's how I'm doing my next build. When I find a clean 89-91 K5, I'm dropping it off at Danny's (aka the Count) in Vegas, telling them to install an LS3 Connect and Cruise package, paint it and call me when it's done. I have done the "One piece at a time, didn't cost me a dime" approach. Too old to do it twice.
I gave up on that guy when he painted the bumpers on a 67 GTO.
Nawwwwww
Knot-Kno-Mo
:bleh:
huh... I wonder how much adjustment you actually have with that. They want 6 credits to license them, so that's $300 in credits on top of the $400 price to buy the MPVI3 that you would need. They must figure if you are willing to spend $16k for the engine/trans then you won't blink at $700 to tune it.
I might have messaged you? Hard to remember... but I'm glad to see you back on here!
I think I got a deal in the works for an ‘07 Escalade with the L92 for cheap, has a rear main leak and the cats are no good. Seller is responsible for smog in CA unless it’s non operational. CARB approved Y pipe and cats is $2K and the shop estimate for rear seal is 12 hours. Repair would cost more than the vehicle is worth…
If it has the L92, then it would be an 07.5 with a 6L80. It takes me about 4 hours to get the trans out now that I know what to do and everything is not frozen together, so 12 book hours sounds about right.
Are you thinking you will be trying to swap that into your 80' K10? You should probably do a search on both VIN's and make sure they are in the same vehicle category before pulling the trigger on that if so.
If i ever have $60k budget im taking a car to martin bros customs.
If I ever have a 60k budget, I'll just take a bunch of time off work and build it myself.
CalSgt
CA
Casey
Chevy K-10 Custom Deluxe
It’s going in a ‘71 Jaguar XJ-6 if I get it, so no smog concerns.
Vbb199
Salisbury NC
Vince
It's true for women too.
Intelligence, Emotional Stability, Good Looking
Power, Reliability, Cost
I see no difference here
Gilmore
Eureka
Christopher
6.2L Diesel
I used the connect and cruise package for my 1984 K10. I used the 350 HO paired with a 700r4.
Craig Nedrow
NADAR UNDER THE RADAR
Washington State
Craig
1973 (have two), 1985
K10, K20, C20
350, 454, 6.2 Detroit
If you do it yourself you can learn something. My LQ4 with 4l80e trans, all wiring fuse box , ECM was 1500 in Portland Or. my LS 1 with t56 was 2500 paulsbo WA 40000 miles
badbroncos27
