Wheel and Tire thread
Auburn, Washington
^ No idear, honestly.
Looks, parts availability, fitment within a body style, performance, not performance. Doesn't seem to be a rhyme or reason. Especially pickups. One would think the business end of a pickup truck would be offered with the most stability possible, for carrying loads. But there you have it, many trucks are narrower in back...
From what i read, it offers best traction especially while turning because your rear wheel wont follow the exact track, and the greater the front width compared to rear, the sharper turns can be, so it can help manuvering. But it sounds like its not going to.. kill anyone or be objectively more dangerous, just has benefits im guessing the hard-to-notice makes it worth it to designers
Auburn, Washington
^Front and rear wheels don’t follow the same track anyways when turning, regardless of a bit of track width difference Or not.
TubeTruck
East TN
Denis
Suburban K10
LQ9
@AuroraGirl is on the right track. I've also heard the front is wider than the rear for better turning stability and better turning radius, at least for these types of trucks.
Swearbody
Birmingham AL
Jeff
C1500
355 sbc
You guys ever done any scaa, drifting, or autocross? I realized this from experience( in failure after failure)
The Physics of it is as follows:
Wider front track = oversteer
Wider rear track = understeer
Perhaps the rear track is narrower to compensate for this under load. If the rear track were wider it may cause heavy understeer especially when loaded heavily.
I have driven a dually as well and it definitely tracks under in a turn waay more than any two rear wheel setup.
The turning radius would be increased by a wider front stance...not decreased
Swearbody
Birmingham AL
Jeff
C1500
355 sbc
The front wheels dont follow a linear track either. Each front wheel has camber,caster and most importantly here...Toe. The toe changes as the wheels pivot. ideally the outer wheel rides on the outer edge of the tire while the inner rides on the inside during a turn.
Simplified version...Its all about turning
Complicated version.. Handled by GM engineers 60+ years ago
There is a lot more going on than just track width when determining the suspension characteristics. Change one thing here and it changes something there.
You can get under/oversteer by changing front tire diameter and compensate for rear track width that way as well. Many variables.
nvrenuf
Mobile, Al.
Might as well pic ***** a little....
My '91 with 7" suspension, 1" body lift, lots of trimming and 43'w on 16.5x12 wheels.
rich weyand
Bloomington Indiana
Rich
1978 Cheyenne K10, factory monochrome shortbox 4x4 in black. +2 front, +3 rear Rough Country EZ-Ride springs & shocks. BF Goodrich All-Terrain TAs on Cragar Series 342 D-window steelies.
I went 2" in the front to get out of negative-arch springs, then went 3" in the back to even up the wheel openings over the tires. The front wheel opening is higher on the squarebodies and it always makes them look like they're dragging tail to me.
FireTruck1984
Michigan
Ted
1984 and 1984
No, it Looks real good ! a level truck always looks better than the “Texas Rake” (higher in the back). although A lifted truck needs a taller sidewall to fill the wheel opening and make the proportions right.
Catbox
Peter
C20 Silverado Camper Special
8 lug 16 x 8 American "Centerline" looking wheels.
We got a smoking deal on them and they look great on the truck.
Now to get some new tires on them.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
1" body lift.... perfect! Nice fender trim job.
nvrenuf
Mobile, Al.
Thanks! It’s almost time to update this, I sold that tire / wheel combo and I’m going with Boggers and beadlocks.
Papa Rosa
