What motors can be swapped into an 87 square body custom deluxe
Jtg87cstmdlx
Gray, TN
Jared
V10 custom deluxe
Hello
I am looking into doing a motor swap to either a 454 big block or to go all out and get a 6.6 dirty max with a six speed to put in my 87 custom deluxe. But I was wondering what all motors will fit into the motor mounts that are pre existing in the truck thanks for the help
MadOgre
NA
NA
NA
NA
NA
You can drop an LS motor in with a motor mount kit available to put them in our ol squares
firebane
Calgary, AB
Curtis
You could put whatever you want in. Money is the biggest factor and how much time you have.
marks86
Latham, NY
Mark
12v Cummins
this pretty much sums it up. anything is possible.
1984dually
Malin OR
Danny
C30
8.1L
Looked into a Duramax swap when I did my Dually. You can ck out Powerblock TV and see what needed to be done to fit it in. Mod oil pan/cut out floor/etc. Any bbc up to the 8.1L will bolt to the factory mounts. So will an LS with plates. Like already stated it just depends on budget and time.
Yep, you can do whatever you want with money being the only factor.
firebane
Calgary, AB
Curtis
Vortec 8.1 with allison... That would be fun.
77 K20
Montana
K20 5" lift
HT383 fuel injected
Allison is huge and sucks up a lot of power. That is why I looked for the ZF-6 in my Silverado. I get much better gas mileage also.
1984dually
Malin OR
Danny
C30
8.1L
4L80E behind an 8.1L. Been running one in my truck for 2yrs with no issues. No cutting floorboards. Easy swap.
350runner
tx
Ceasar
I've been reading on this trans swap for some time. In the new trucks a 2 inch body lift is required. How are you liking this trans? Any issues with the clutch failing?
1984dually
Malin OR
Danny
C30
8.1L
I have never heard of needing a body lift with a 4L80E trans. Allison maybe. Anyway I haven't had any problems with the 4L80E in my truck. Been in it for a couple of years with no issues
77 K20
Montana
K20 5" lift
HT383 fuel injected
The Allison was the transmission that was so big that the HD series trucks needed a "body lift". They made the frame taller to make some room for it.
350runner
tx
Ceasar
350runner
tx
Ceasar
How are you liking this trans? Have you had any issues with the clutch failing?
78silverado
