What motors can be swapped into an 87 square body custom deluxe
77 K20
Montana
K20 5" lift
HT383 fuel injected
How are you liking this trans? Have you had any issues with the clutch failing?
I've towed with it for something like 25,000 miles and love it so far. For going up hills it is nice to be able to chose from 3 different gears for highway speeds.
The clutch hasn't been a problem yet, and if it does I'll get a south bend clutch to replace it. The only issue I ever had was towing when it was almost 100 degrees out. After a few hours of non-stop highway driving I pushed in the clutch to shift, and there really wasn't anything there. Had to pump the clutch a few times to get fluid back down there. Guess it can boil out when the exhaust is just a few inches away.
I also like how first and reverse are straight up and down from each other. Makes maneuvering when parking a trailer much easier.
And the gas mileage is very good (for a 8.1L) If driving empty on the highway I usually get 15.5 mpg on the way to my parents (3 hour drive).
350runner
tx
Ceasar
Thanks!
jlyon1006
