mxer147
Colorado
Jack
k20
Sanding and filling, should be spraying epoxy primer soon.
Tank6x2
Edmonton Alberta Canada
Kurt
C30
350, TH400.4:10 gears 2WD
pinballlarry1
Kalispell, Montana
Larry
250 6 cylinder
Got in several hours of work while the wife was away. Changed the gear oil in the 4-speed manual trans, a full one gallon drain and fill, did get a bit messy. Also changed the 1/2" npt drain and fill plugs to magnetic plugs ($8 each on Amazon from Crimp Supply).
Installed two LOUD horns behind the grill:
Super easy
Began planning to install these Bosch old school fog lights:
I have no idea where this kit came from, but I found it buried in my garage so it's mine now.
Strick
Dunn, NC
Harold
C20 Crew
Moving spare parts, Squares & FBody stuff. I used the tractor to place the front clip on my 76 just to free up yard space. What a face-lift tho.
brooksman9
Olive Branch, MS
Patrick
Silverado & Custom Deluxe
350 & 305
Finished the cab corners and painting on the white truck. Going to let it sit until I'm off on Thursday and then set the bed back in place.
Tank6x2
Kurt
C30
Looking beauty!
Tank6x2
Kurt
C30
Modifying the underside of the hood one last time, wasn’t clearing the cowling as it went up it would catch - getting there slowly.
JamesSam
VA
Sam
Silverado V10
5.7 L 350 v8
Met a friend this morning and saw his ‘53. Then after, picked up my wife and got some plants for the yard.
Wow. That's 2 beautiful classics!
incubus2432
Grafton, Ohio
Shekkie
There were some holes drilled in the bed already that I’d guess had eye bolts through ‘em at some point. I hammered the deformed holes flat, drilled to 7/16”, drilled a few more holes and installed stainless rivnuts to hold tiedown hooks. I can say the youtube “bolt/washer/nut” combo was a PITA to install the rivnuts. I shoulda just bought the tool and I woulda been done in 10 minutes instead of 90. I’ll bolt the tiedowns in after I finish my DIY bedliner (Monstaliner).
JamesSam
VA
Sam
Silverado V10
5.7 L 350 v8
Was in the process of replacing the steering stabilizer(dampener). The old one came off fairly easily and was loose as a Goose so I was very excited to be replacing with a new one that was toight like a toiger. Then realized these are different bolts and different shocks completely. I looked up exact fit for my truck on Ranchos website got the part number then found it at a NAPA. Somehow things aren't alike. New bolt for the extending side of the stabilizer doesn't fit through my tie rod end. Copying and pasting this to a thread about this...
evlblkrfl
Southern Kalifornistan
Ive been scouting around here for a little bit and wanted to share too. The information you guys have here is as good as you can find anywhere. I picked up a super honest original truck.1977 K20 with a 350 SM465 Np205 14bff and dana44....the tag says 4:09 gears. Supposed to have lived most of its life in Wrightwood California. Here she is the day I got her home. Sorry if this is the wrong place to post. I'm mentally incompetent pretty much
evlblkrfl
I have plans for it....and some progress pictures...
2manysquares2care
