Curt
Loco Hills
Curt
K-30
No hydroboost.It’s gone after the rear disc brake conversion.I don’t know any off the specifics of the PSC.I looked up the specs.It doesn’t mention gpms or psi.I think it’s just a overbuilt version of what I have,and new,not reman in china
link? I know some psc tell you to reuse your valve
Damn,you definitely know some power steering!Thank you
if the tolerances end up being too loose in a new pump, the edges that ride in the bore are too rough, I wouldnt want to put it into a good pump with a known good bore like your incoming one because its all bured up and scratched and those metal bits probbaly scored the pump itself in my situation here. but a good example ofwhat you hope NOT to find lol
Tank6x2
Edmonton Alberta Canada
Kurt
C30
350, TH400.4:10 gears 2WD
Threw the box on last week and started hood modification today
80BrownK10
Greenwood, SC
Nate
Just double checking this is a 30 under bearing right?
80BrownK10
Greenwood, SC
Nate
And this is a rod cap. I don't have a clue what any of these mean and google hasn't helped me yet.
QBuff02
Central IL
Quincy
Generally if the crank has been turned it will be marked on usually the first counterweight with how much it has been ground. example there will be like M .010 R .010 stamped (denoting how much the journals have been ground) into it somewhere. Bearings that are oversized (for an undersized/ground crank journal) will be marked as such with a corresponding .010/.020/etc. There's a good chance those are the factory bearings you're holding. The only way to know for sure, if you have any doubts, is to mic the journals for a measurement so you can order the appropriate bearings. More pics are better if you have any more questions.
80BrownK10
Greenwood, SC
Nate
I created a thread so I guess I should send folks to the link instead of having two places I asked the question. I posted a pic of the crank where it was stamped. Follow it over there and I will have more pics there. https://www.gmsquarebody.com/threads/help-identify-these-bearings.35305/
Auburn, Washington
Installed a new electric fuel pump relay with a key-on 3 second prime. Whoever installed the engine had the fuel pump wired direct to ignition source. No bueno setup. Not safe.
It works as intended. It’s similar to this one.
zapattack
