Mossyman
Mississippi
Richard
4.1 1 BBL
I had to hit the brakes really hard the other day because of some jackwagon backing up on my side of the road...around a curve. When I hit the brakes the back end spun sideways. Luckily I was able to steer out of it and didn’t hit the moron. Checked the left front and found out the brake line running to the caliper was stopped up. Fixed that and replaced a blown fuse to the brake lights.
OldBlueDually
Minnesota
Justin
1976 GMC
C30
455 Olds
I "WAS" doing this....insulating the interior
However, this ended up stopping me. The damned drivers side seat belt felt loose to the cab, so I lifted up the original cab insulation and saw why it was loose. So I gave it a good yank and out it came...
SO instead of continuing what I wanted to do (insulate interior), now I have to fix this damned thing. Thick steel will go underneath, lighter gauge on top.
Before I do bodywork & paint in a few years, I should start looking for a nice cab for this crew.....
Good thing you discovered it
Joshua Keith
Memphis
Joshua
Got the rear axle painted and the Tuff country EZ-Ride 2” lift installed. Have to finish the a/c install, then tackling paint next! Ready to be able to drive it again!
75Monza
Colville, Washington
K30, K20, K20
May have found me another parts truck, an '89 C30 flatbed, 454, 4 speed dualie, going after it tomorrow and if motor sounds good it's going on the trailer.
87scotty
Central il
Andrew
V20
5.7 for now
got the new th400 in and shes on the road again. also new hub lockouts the all metal warns! Hooked up the vac advance and wow i can just feel the fuel economy going from 5.5-6 to like 35mpg wish i woulda done that years ago just topped it off yesterday so will now actual fuel eco. in a couple days
Poppy 87
Bloomingdale GA
R10 Silverado
Hopefully the mileage doubles, my 87 R10 with a 305 and 415,000 miles got 10-12 mpg when daily driven. TH400 and 3:08 gears
Sent from my XT1254 using Tapatalk
87scotty
Central il
Andrew
V20
5.7 for now
Gonna guess 7-8 mpg with a tailwind and light throttle. ( why go light throttle with that setup!!)
haha i like to daily drive it to much lmao
87scotty
Central il
Andrew
V20
5.7 for now
forgot to mention picked up another square lol 1980c70.with the 366 put about 15 miles on it and lost all oil pressure! so i drug it back to a lot my work owns dropped the pan and found it sheared the oil pump drive anyway new oil pump and shaft and back on the road not a bad by for 975 smackers
RipTideTiger
SC
V1500 Suburban 4x4
5.7L
Haven’t completed much mechanical work lately, but that is upcoming later this year. I have stripped the interior down, fixed some corrosion issues, refurbed the door covers, sprayed Lizards Skin ceramic insulation, and had a guy reupholster the seats. Still need to redo the headliner, haven’t decided how/what yet.
dannyphx
