Wait.
Thats a NP208?
Also, is the cross member a good or a bad thing?
Also, slow down youre blowing my mind. This may explain a few things.
I need to sit down
Yep, it's a 208. Your t-case shifter probably has a little plastic console around it, correct?
yes
It would explain, why oh so long ago, I think you mentioned I shouldnt have that shifter housing in my truck based on the age. This would be like at least a year ago lol. i mentioned you in my thread on the topic if you have time to impart knowledge :)
That looks like it already has a skid plate.
Yes what im saying is id like to put that on my W truck, do you think its a direct bolt over or maybe even drill holes or do I need to get/fab one like yours?
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
I see.
Honestly, the easiest thing would be to look on eBay for that couple that sells chassis parts, buy the right part, turn your crossmember around and just bolt it on. I think it was Ray and Samantha. I got the missing crossmember for my spare tire mount from them. Nice to deal with.
You probably could fab one up, but I'd rather spend $40 for a bolt on solution. Time has value too.
ajd89
Central Michigan
andrew
More backwards progress. Cleaned my case and have been getting parts here and getting my frictions set right. (that part has me the most nervous) Buddy came over to look over my work and seen the crack. I swear I looked it over and didnt see it before. Thats trans was really tore up. Guess ill be cleaning the trans case I brought for parts that looked like it had been sitting in a lake.
SubDominant
California
Keith
V1500
5.7L
That stinks! But at least your buddy caught it before install. That would really stink!!
Loco Hills
K-30
Almost done with a true one ton swap.Did all gear work and bearings myself.With a few tools from Harbor freight I might add....
QBuff02
Central IL
Quincy
Drove it! Haven't really been able to drive it in the last few weeks. However, it developed a tranny fluid leak on the way home but it was too hot to look at, so I backed her back in the garage and will investigate one night this week.
Poppy 87
Bloomingdale GA
R10 Silverado
This:
Does that affect towing capacity? Looks really good
Sent from my XT1254 using Tapatalk
Big Chip
Michigan
Kevin
C35
Thank you. I had to take the overload springs off but I added airbags so it should be about the same. Those pictures are with no air in the bags.
miles movado
