TPISly-C10
Boucherville QC Canada
Sly
C-10 shortbox
LQ4 6.0L
Put back all the stuff on my friend truck that is have not time to finish it! :)
PunH2O
Btown Pa
Pun
R10
Lets get her doneee
Before...
Bald AF tires that came on the wheels we wanted.
They were considered "junk" by the seller and we used them all the way up.
After with white letters out of course!
@Maxwellvis has verified they bark when you grab 2nd hard as well as they are super smooth at 80mph on the freeway.
you certainly got use from that one. I would have a panic attack way before getting close to that just because of gravel patches and sand and dirt and open diff and rain and lol... thats not counting the wet, or dry..grass!
Howdy everyone! Long time no see. Been very busy with work, life. Between extreme hours and buying a house, things become quite hectic and i can't work on squares as much :(
SO anyway i was able to spend some coin and recruit my brother for some Jimmy sandblasting. Had to buy a compressor and some media. Borrowed the blasting pot off a buddy. Was able to get 3/4 the way done today. Don't know what i'd do without the man the myth
that would probably work like a knife on my bed.
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
Gassed her up :
Then, went to Wally World for MMO, which they had, and engine degreaser, which they did not have.
So, experimenting with Simple Green.
Heard about it, but never used it before.
Begone, old oil and grease residue!
Make room for the new.
:Big Laugh:
mtbadbob
Montana
Bob
V20
Not as extensive as some of you guys recently lol
Got some goodies in from ORD and some other parts. Yesterday came the zero rate blocks to help the saggy rear of the Burb, conversion lug nuts so I can finally use my center caps, new drag link, and pitman arm. Sad thing is the truck is still in the tranny shop for warranty work. Oh well at least I can cut the center caps up to make room for the locking hubs.
3" hole saw works perfect for the hub bore!
Powerhouse Ranch
3G Connoisseur
PA
Luke
'80, '86, '88
C25, K5, V15
So i've finally wrapped up the new gas tank - sending unit - fuel pump on the parts Burb. Wanted to see if i could get it to run after about 15 years of sitting. Figured it's better to drive it around than push it around. Everything was going great on this dark rainy day until i realized the fuel pump wasn't working; i couldn't hear it and it wasn't sending any fuel up to the 'ol fuel-make-it-happener. Like i said, it has been sitting. Just need to check on the connections, wiring and grounds, probably something like that. Wasn't really in the mood to go crawling under that tight rusty machine today. Hopefully later this week. But i recorded the intial starts, only from pouring some fuel right down the throat to get her started.
gmbellew
Kansas city
glen
suburban 1500
check to see if you hear the relay clicking on the firewall. backup power comes from oil pressure sensor I think.
Ken B
indiana
ken
I got the the undercoating done. Later this week will be cab Tipping and getting it on the frame. In the garage so there is heat
AyWoSch Motors
The Parts Guy
New Mexico
Ayden
K1500 Sierra
350ci V8
Nice!!
Hey, if that's a parts truck, you wouldnt be willing to part with those headlight bezels, would you? Dont think they'll fit the your Jimmy.
Camar068
Kentucky
10 yrs Air Force
Went quiet on the exhaust. The new cherry bombs were not the same brand I had on the camaro in the '90s so instead of trial and error I said screw it go silent and be done with it. I definitely need the tach hooked up.....before I went by sound. Anyone got a tach to replace my fuel gauge? Not sure if I can swap em, haven't researched it yet.
May do the camaro gauge swap if needed.
Powerhouse Ranch
3G Connoisseur
PA
Luke
'80, '86, '88
C25, K5, V15
is there a relay on the firewall? That one isn't by the throttle pedal is it? Don't think its on the fuse block(not too good with "digicals")
Powerhouse Ranch
3G Connoisseur
PA
Luke
'80, '86, '88
C25, K5, V15
Nice!!
they are different from my Jimmy, which i already have covered. And i think i owe you since those clutch springs. When i get a minute i'll get them out to ya bud
AyWoSch Motors
The Parts Guy
New Mexico
Ayden
K1500 Sierra
350ci V8
Wow, well thanks man. That's awesome. Been looking for a set like that for a long time.
Dont worry about the springs, that was a gift, no need to pay me back.
And those bezels are worth more than a couple old springs. I can give you something for them.
Turbo4whl
Downingtown, PA
Wayne
Jimmy
These are the gauges that would be in a pickup:
This, with the fuel gauge in the tach would be from a C60 medium duty truck:
Either one could be made to work. If you use the medium duty truck combo gauge, you need to remove your original gauge resistor on the back of the fuel gauge. Then replace the one on the combo gauge with your original. The tank level float of the medium duty has a different range.
eherbaugh
