Vortec Heads vs OEM SBC Old School Heads
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
Thanks for the wealth of great info C4. I copied the link to a new thread and its worth being STUCK !!! Got'R Done !!! :High 5:
Dave1978
pittsburgh
Dave
1976 or 1981
c10 and GMC 1500
I like the vortec heads as well I have a set on ice for my next truck engine project.I read a test in a magazine years ago that tested all of GM aftermarket heads and they out flowed most.They are nice also with the center bolt valve covers cuts down on oil leaks a lot.
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
The only problem is; They nail you in the ass for an intake manifold.
Yep, but still glad there is an aftermarket intake that allows the use of Vortec heads on old school motors. The only other drawback I don't like about Vortec heads is the max lift issue. Got a great head, but can't run a biggo cam with them without extensive expensive machine work.
GreaseDog
Elkhart, IN
1977 K20
1980 K2500
During valve guides down is cheap.
It that all that is required? I thought the valve spring seats had to be recess cut deeper and also wider? :shrug:
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
For certain springs, maybe. But for most springs you just machine the valve guide down so the retainer doesn't make friends with it.
Cool, I thought the machine work was much more extensive than that. I was wanting to run about a .525 lift and .310 duration cam, and thinking I'm toning down to about a .510 .300 duration. Also want about 11 to 1 to with valve overlap, I should be OK with 89 pump gas, so Vortec heads would be for me. I want the sleeper effect or at least appearance since with that cam, it won't be no sleeper for sure. It'll be a biggo bumpitty bumpitty bump idle to it.
Dave1978
pittsburgh
Dave
1976 or 1981
c10 and GMC 1500
intake
I've seen them as cheap as $75 on Ebay the ones to convert the heads to run with a carb.
Guardian
Jeff
c 10
Cam reccommendation
HotRod PC I have a 500+ lift in mine and it is a sleeper, most don't notice it. It is the Lunati Vodoo roller, it runs well on pump gas.
Being roller helps on making sleepers. Also other specs like lobe seperation help too. Do you know which cam grind you have???
Guardian
Jeff
c 10
Yes, it is a VDSC-262. The seperation is 112.
Certainly a good low end power cam, but it doesn't appear to be roller, and doesn't provide over .500 lift. It can get that kind of lift with 1.6-1 rocker arms though. Maybe you just have roller rocker arms and they are 1.6-1 rockers if someone has told you it's a roller cam with over .500 lift.
http://www.lunatipower.com/Product.aspx?id=1983
Guardian
Jeff
c 10
It is a 507/515 lift roller. I double checked the grind number from the card, VDSC-262. It does make a ton of low end, but I wanted to make sure it could be used as a daily driver.
goodwrenchca
