Turbo350 w/shift kit slamming 2nd gear
How do we get the accumulator cover back on? Can't figure out how to get the snap ring back in the groove while pushing on the cover hard enough to see the snap ring recess. There has to be a trick to it. TH350 is still installed on the truck.
Yep, Matt said the trick. Most people put that O ring over the cap and try to push it in place. NOPE. Put the O ring in the groove of the case FIRST, THEN push the cap in and set the snap ring.
AZ Highlander
Prescott AZ
Frank
K15 (aka V1500)
350 (5.7L)
Lube the seal with vasoline, place the o ring in the case, right up against the step it seals against.
Lube up the cover, put it square against the seal in the bore. Use a large socket and a prybar against the floorboard to push the cover in. Once it’s in place, reinstall the ring.
It will take some effort to install.
Thanks Matt and HotRod! Its a K25, so there's both an exhaust pipe AND a driveshaft there. Pretty tight prying. Gonna try to see if there is another location to pry against and if there is a different angle to pry that we haven't already tried. Keeping that socket on the cap, the prybar on the socket, and the cap straight in the hole is a challenge in itself. Thanks again.
If you can push hard, and put the seal IN THE CASE FIRST, you should be able to push hard on the cover and then start the snap ring and then use a screwdriver or something to feed it into the grove all the way around. Prying is needed to get it out, but I have put them back in without having to pry. There is actually a special tool that's sold for that acculumator cover. I think it's usually about $10 or so. The tool just makes it gravy gravy and sooooo simple. But the biggest key is, set the O ring IN THE CASE FIRST. Most people put the O ring over the cover and try to get it in. That'll never happen without damaging the O rings.
ChuckN
Bellinham, WA
Chad
When I did my accumulator cover seal, I didn't know the trick about putting the seal in the case first. I used lots of dielectric grease on it. It doesn't leak... yet. It's been almost a year.
AZ Highlander
Prescott AZ
Frank
K15 (aka V1500)
350 (5.7L)
The boys got it to seat. They're 15 and 17 and sure can wrench. As their homeschool auto shop teacher, they're getting to the point where they're gonna be teaching the class soon. Will get some photos up of the newest square to join the fleet soon. An 82 4x4 burb for the 15 year old. He got his permit and is learning to drive on the rig that he'll likely have for a good long run.
If you have the room.
Pnew
