Transfer Case Crossmembers & Skid Plates
dbones85
Alberta
Darren
Scottsdale
Does anyone know what crossmember, type/shape, to use on a k20 with an nv4500/np205 setup?
Sent from my iPad using Tapatalk
Any of the '85 and up crossmembers. That would be the W or S type.
Should be either of these. The W one is pretty hard to find since it was only used either 85 and 86 or maybe 84-86. The other type is better IMO anyway. Had a wider footprint for stability and is a couple inches more shallow so you're not as likely to snag it on something and bend it up. I've seen as may bent up W members as I have non screwed up members. Never seen the other type damaged.
NicBop03
Charlotte, NC
Nick
1988, 1990, 1987, 1973
K5 Blazer, R1500 Suburban, V10 Suburban, C30 Pickup
5.7L 350ci
does anyone have one of those drop down cross members they'd be willing to part with?
By dropdown, what do you mean sir??? Maybe suggest a post # that it's pictured in and which pic from the top it is. Like for example Post #33 Pic #2 from the top.
NicBop03
Charlotte, NC
Nick
5.7L 350ci
I was talking about the second picture in post #21. I actually found one locally for about $60. I've already installed it on my blazer now i just need to put the transfer case in and measure for a driveshaft.
i also am in need of that strut rod anyone got 1 or know where to get it
I mean random but I can look in my shed.. one of my trans might have one on it. I'm sure it has a part number? It's for th350 and th400, but no idea if it's same one
There's s few different lengths of strut rods, depending on trans/t-case combos.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
Here's a 700r4/np208 tall tcase adapter, no skid plate, 84 suburban
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
This I believe is a 700r4, or possibly a th350/np208 short tcase adapter and skid plate blazer I believe 85-87
HOTFOOT
northwest ct
michael
gmc k3500 srw
This one seems to be used for everything pre '85. The NP203 skid plate employed two of these crossmembers, with the second one just supporting the end of the skid plate and not the trans. The K30 version of this crossmember was a little more flat to accommodate the taller frame rails.
my k3500 th400/205 only has a 2.5" rise
HOTFOOT
northwest ct
michael
gmc k3500 srw
my 80 k3500 th400/205 is 33.25" over all
rfeth
