Transfer Case Crossmembers & Skid Plates
my 80 k3500 th400/205 is 33.25" over all
I've got a selection of these, I'll try to get measurements like that.
This I believe is a 700r4, or possibly a th350/np208 short tcase adapter and skid plate blazer I believe 85-87
I'm thinking this is 87 and later. IIRC, 85 and 86 used the W crossmember.
That is the 4x4 trans cover with 1 of the strut rods that anchors to the motor mount.
There's s few different lengths of strut rods, depending on trans/t-case combos.
IIRC, if you have an NP208 or NP241C, they are all the same no matter what Transmission you have. This is because the overall combo length is the same with the difference of the transmission being made up with the Tcase adapter. Same one that fits a 700r4/NP208 is the same one that fits a Th400/NP208. Driveshaft lenghts also stay the same and so does the yoke on the rear driveshaft since all the outputs on the NP208 and NP241C are 32 spline outputs.
So for example, if I take this 305/700r4/NP208 out of my K5 and put in the 454/Th400/NP208, I can use the same strut rods, same driveshafts and same crossmember using the same crossmember mounting holes in the frame. One of the things I've always loved about GM, keeping things universal and intechangeable for many years. Now why Chevy got the different bellhousing than BCPO I'll never know.
Yep, that is correct. The round pattern stuff was much more interchangeable. There were a few more different lengths involving the 205 combos and then the 203 also.
I wish it were standard bellhousing :(
Julz874x4
El Monte , Ca
Julian
1500 4x4 stepside
I'm looking for a skid plate to put on my 87 v10 ..
Sqbody
Las Vegas
Rob
Looking for an S style crossmember, who has one they'd be willing to ship to Vegas?
Thanks in advance
Thanks in advance
S style? Do you we have a pic of one above? If so, I'd get that post # and describe which one it is, on the left, or the right etc if it's a pic with multiple crossmembers. I have a feeling you're talking about the later one we've said appears to be for 87 and later.
Sqbody
Las Vegas
Rob
The same as post #33 pic 2, the 87 and later s style. I have the w style now, and need the s style to use flipped (pass side on driver, driver side on passenger) as I added a NWF black box and clocked the t-case down, and run the front driveshaft under the crossmember as apposed to above. Truck has 24"~ lift on 44' boggers and working to get a front drive shaft to work in it. Let me know if you hae anything, Thanks
How big of a hurry are you in? I know I have 1 but certain it's at my dad's somewhere. I might not get back out there til Labor Day weekend. Not sure what it weighs and how much shipping would be from OKC to see if it's even worth it.
Sqbody
Las Vegas
Rob
Not really concerned about shipping cost, I can also provide a shipping label and have it billed to my fedex account if that's easier also. The sooner the better would be great, but Labor Day weekend is just around the corner anyway. I know they are out there, I just haven't had the best of luck locating one locally yet.
I'll try to look around here and see if I have one here but I'm about 95.5 certain it's in the back of the K10/20 project that I had towed out to my dads. If I come up with it sooner than Labor Day weekend, I'll sure let you know. Fed Ex will require it to be in a box won't they? IIRC, they require everything to be in at least corrogated container which in short is a cardboard box.
bryanedge117
