- Aug 29, 2010
- OKC, OK
- HotRod
- 85 K20 LWB
- Silverado
- 454 - Turbo 400 - 3.73
So I was heading up the mountain when I got a call for a private tow. As I was running out of cell coverage I got the address and headed out there. I showed up with our short rollback, only about a 19' deck. I arrive to find that the tow is for an 07 Dodge 3500...
Crew cab...
Diesel...
Parked nose in.
My gut feeling (which I should have listened to) said to go back to town and grab the bigger rollback. Instead I decided to attempt to load it. Of course since it is nose in I have to grab it by the tail. With about 4" on either end I managed to get it loaded. The hydraulics didn't like moving the deck back. It groaned all the way. Fortunately it was only a 3 mile tow but I do not believe I will attempt that again. I don't think it would have been as bad nose first as that would have centered the weight better. I still think that was too big a load for that truck. The steering was a bit light on that trip.
I guess it's time to pay more attention to my gut.
It would have been nice to have had the vehicle info going in but they didn't have it all.
Believe it or not, that longer truck, probably a 21ft, may not have lifted it. That extra 2 feet and having the weight further out on the end. Of course you can load it the same way. You can work your bed and you'd be amazed at what you can get it to lift when you think it's not going to happen. Especially when you don't want to put it back down and go swap trucks. Not sure how true, but when I picked up this load, I was told these 4x4 F450's weighed over 12,000 each with the equipment that was mounted in the boxes. Very well could be true. I did break a winch line loading the first one. I ended up backing up into the the other truck to help finish loading. Got it on deck, used the E brake and Park on deck, drove ever so slowly to a hardware store to get parts to sorta fix the winchline, then went back and got the other one. That wheel lift is maxes right there, and that's cuz I used a floor jack to help it. If those were 12K ea, then I was grossed out at well over 40,000 on a 26,000 truck.
