TOW HOOKS
Powerhouse Ranch
3G Connoisseur
PA
Luke
'80, '86, '88
C25, K5, V15
Anybody know where I can find (or are willing to sell) genuine GM tow hooks that go on frame beneath front bumper? I don't think they change at all between minor 73-80 and 81-87 differences, but if they do, also indulge me. Thank you
https://www.ebay.com/p/1429688912
here is what it looks like on my 78
that looks like its from a 81+, if that is, assuming the hook is the same, i am thinking the hook goes at an angle sweeping backward vs the older trucks was straight up? Im thinking there may be a design change 81+
im not sure how much different the frame horn being rounded vs not rounded like 81+ would affect this or not
But There is a reinforcement plate on the backside of each hook, too, that i feel is probably important
quick google search found this:
which tells me the direction of the hook is unchanged but the way it mounts is obviously different for the frame horn.
im not sure if a 73-80 uses a reinforcement for the hook then.
also, recovery hook would be your proper terminology, i wouldnt recommend towing with the hooks.
I can check my frame in the morning if you want to know if it has a reinforcement. Which truck you need for, your 1980 or your 1988?
SquareRoot
That's the only solid piece on your truck...:signs8:
Powerhouse Ranch
3G Connoisseur
PA
Luke
'80, '86, '88
C25, K5, V15
the '88 and thanks a bunch (i never meant to tow with them, LMC uses that term when buying air deflectors)
Do they need to be factory? There’s a guy near me that sells some heavy duty ones that are laser cut and have a circular hole instead of the hook to take a standard horseshoe shackle.
bigcountry78
Hickory, North Carolina
James
K10 Custom Deluxe
They do change. 73-80 are shaped like a candy cane, 81 and up are shaped like the curved one pictured above. The 81-up are easier to find, there are usually several sets on eBay. I don’t have a spare set, or I’d hook you up.
Powerhouse Ranch
3G Connoisseur
PA
Luke
'80, '86, '88
C25, K5, V15
much appreciated anyway
Powerhouse Ranch
3G Connoisseur
PA
Luke
'80, '86, '88
C25, K5, V15
pictures?
Keith Seymore
Motor City
Keith Seymore
4.3L
seanhatesregister
