TOW HOOKS
Powerhouse Ranch
3G Connoisseur
PA
Luke
1980 & 1988
C25 & V15
454 & 350
Anybody know where I can find (or are willing to sell) genuine GM tow hooks that go on frame beneath front bumper? I don't think they change at all between minor 73-80 and 81-87 differences, but if they do, also indulge me. Thank you
https://www.ebay.com/p/1429688912
here is what it looks like on my 78
that looks like its from a 81+, if that is, assuming the hook is the same, i am thinking the hook goes at an angle sweeping backward vs the older trucks was straight up? Im thinking there may be a design change 81+
im not sure how much different the frame horn being rounded vs not rounded like 81+ would affect this or not
But There is a reinforcement plate on the backside of each hook, too, that i feel is probably important
quick google search found this:
which tells me the direction of the hook is unchanged but the way it mounts is obviously different for the frame horn.
im not sure if a 73-80 uses a reinforcement for the hook then.
also, recovery hook would be your proper terminology, i wouldnt recommend towing with the hooks.
I can check my frame in the morning if you want to know if it has a reinforcement. Which truck you need for, your 1980 or your 1988?
SquareRoot
That's the only solid piece on your truck...:signs8:
Powerhouse Ranch
3G Connoisseur
PA
Luke
1980 & 1988
C25 & V15
454 & 350
the '88 and thanks a bunch (i never meant to tow with them, LMC uses that term when buying air deflectors)
Do they need to be factory? There’s a guy near me that sells some heavy duty ones that are laser cut and have a circular hole instead of the hook to take a standard horseshoe shackle.
bigcountry78
Hickory, North Carolina
James
K10 Custom Deluxe
They do change. 73-80 are shaped like a candy cane, 81 and up are shaped like the curved one pictured above. The 81-up are easier to find, there are usually several sets on eBay. I don’t have a spare set, or I’d hook you up.
Powerhouse Ranch
3G Connoisseur
PA
Luke
1980 & 1988
C25 & V15
454 & 350
much appreciated anyway
Powerhouse Ranch
3G Connoisseur
PA
Luke
1980 & 1988
C25 & V15
454 & 350
pictures?
Keith Seymore
Motor City
Keith Seymore
R10
4.3L
78ALB
