The el cheapo 1978 4dr nova base
jake wells
Can i be me?
Brownsville Kentucky
jake
custom deluxe 10
Got this for a low sum it is a base model with no options and features a 250 I6 3spd manual which is getting a S10 T5 swap. No a/c power steering or power brakes but does have a radio. The axle is 2:73 which is going to get swapped later.
Still fun little car to drive and it is a work in progress i am currently waiting on my custom clutch to get finished since i had issues using a stock S10 clutch disc with my flywheel.
It is a ceramic button clutch with a 1 inch input shaft diameter and 14 splines flat diaphragm it should last the rest of the cars life since i intend this to be a cruiser and not a hot rod.
The paint is light blue metallic if anyone is wondering.
Neat car!
What's the reasoning for that clutch though? A puck style clutch is usually very grabby and on/off feeling.
And I thought GM only ever used 10 or 26 spline?
RetroC10Sport
Green Bastard Parts Unknown
Jay
pontiac aztek
I was looking at a '78 4 door 6 a while back, odd car, 3 speed on the column, A/C and power locks but nothing else.
rpcraft
Robert
LS 6.0 364 CID
So, Ummmm... Interested in selling her? I have a 6.0 LS and 6 speed driveline itching for a granny sleeper....
jake wells
Can i be me?
jake
custom deluxe 10
Neat car!
excessive chatter the original clutch is a 10 inch the S10 T5 uses a 9-1/8 my trans came from a 87 that has a 2.5 in front of it. it has a 14 tooth input shaft spline.
rpcraft
Robert
LS 6.0 364 CID
if you are going to drop a boat anchor like a 4.3 on it why not just put an LS in it? You can put the carb intake on it and swap a 5 or 6 speed out of a F body on it as well.
fussfeld
east coast
j
c-10
4.3 v-6 262CID
Another good thing about these novas and other X bodies is they came with 8.5" 10 bolts, i
think?
P.S., the 78 i owned briefly could run 15.5 1/4 miles times bone stock.
LM1 350 and i think 3.08 rear gear.
wow. cool little car to tinker around on :) I'd definitely rock it!
rpcraft
Robert
LS 6.0 364 CID
think?
I believe so. Nova's were actually good all th eway up until the last ones, so far as the axles and body strength goes. I always like the idea of finding a crew cab and dropping in a smooth drivetrain with a set of buckets, because I don't think a 5 or 6 speed will clear the bench (at least not without some obvious alterations). Once you do that do a little clean up of the interior, you got a nice huge trunk to put some subwoofers in and still carry a few dead bodies, then some Vintage Air and a couple of cup holders with some darkly tinted windows and your off for doing the Power Tour in style!!! I might spoil myself and do a 4l60E for starters just to make it nice and cruise friendly with no holes in the tunnel (and still maintain some cruise control).
Crispy
Carbon County, Pennsyltucky
Suburban V1500
I always wanted to build a 4 door nova with a 3.8 F body driveline as a daily. Cool styling, good economy, and decent enough power.
A cummins 4bt would be a sweat swap too.
Carb'ed Vortec 350
Cool car! I first saw this on my phone. Now on a computer and I see the front blinker lenses have the Bowtie molded in.
jlyon1006
