Summit Brand Headers???
JGV66
New york
Joe
Has Anyone Had any luck using Summit brand Headers? I am asking because i can't find a set of headers in stock for my 1986 K 10 other than Summit brand. I want to buy Headmans but i can't find any in stock. They are all back ordered for months. i am looking for stainless steel. Any info would be appreciated.
77Dmax
vt
Joe
Anything that is summit branded is usually bottom of the barrel for quality. Few things in this hobby are worse than cheap ass headers!
A buddy of mine put the Summit brand big block headers on his C30 a couple or three years ago. They fit well and he has had no leaks out of them. He did use Remflex gaskets though, not the cheap paper ones.
Normmus
Saskatchewan
Norm
I bought a set of their long tube ceramic coated ones and couldn't get them to fit on a 77 K10
ali_c20
Austria
Alexander
C20, K5
Cheap chinese replacement fenders, doors and body panels.....
JGV66
New york
Joe
Im seeing mixed reviews everywhere
Thanks for the reply.
squaredeal91
Cave junction Oregon
Greg bush
1991 SB
5.9 Cummins 12 valve
in my opinion there good. I heard once years ago they were made by flowtech and I have some of those and like them. Could have gone down In quality over the years like allot of other things.
ChuckN
Bellinham, WA
Chad
I have a set of their ceramic coated on my C10, but is lowered and for a Chevelle for more ground clearance.
FWIW, good quality. Nice thick flanges. No complaints, but with 4WD you’re jumping through more hoops than I am.
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
If you know the part number Amazon might have some in stock. I bought a set for my 82 from Amazon that were Hedman brand.
1lejohn
texas
john
k-1500, 2500 HD
I have the ceramic coated ones on my 85 K-10. The coating is not the best. The headers themselves are not bad quality. I don't have the bars that run from the trans bell housing to the motor mounts. If you have those still on the truck, I'm not sure of the fit. Notice the frame butchery on the driver's side. It was done by a po.
legopnuematic
Licensed Junk Dealer
MO
Spencer
Fwiw, the Hookers on my 76 are their ceramic coating, and looked like yours. They were on my buddies blazer first, and only a couple years old, blazer was a fair weather vehicle too. The ceramic coated hookers on my bosses challenger are the same way.
What is weird is when I sand blasted mine, the “rust” was in between the steel and a layer of the coating, not the steel itself. I cleaned them up and hit them with silver BBQ paint and it’s held up good so far.
EvilGenius
Metro Detroit
Darien
I haven't bought their headers, but in my experience Summit quality is pretty good. Not getting top of the line but I think they are good quality for the money on most things. My summit brand carb and alternator have been great so far.
Also they are the best place to buy car batteries. No core and free shipping. And they actually protect the battery in good packaging compared to amazon.
Bennyt
Surprise
Ben
I have Summit Headers on the C10. I found the flanges to be nice and thick and the fit was perfect. The tubes appear to be high quality and the coating was very good. The truck is a new build so I can't tell you long they will last as I haven't run them yet. On a fresh motor, they installed in just a few minutes and did not have to fight to get them in and bolts were easily to get to and torque.
JGV66
New york
Joe
Thanks for all the responses.
I called Headman & they told me it would be 12-month minim wait for stainless steel. they only have one welder that can weld stainless & can't get any help. they did have their steel HD ceramic coated headers in stock at various vendors, so they recommended them. So, i found a set at Jegs on sale and ordered them. they arrived today. I have to see how they fit & how they hold up. My truck is in the restoration shop, and I want to hang them while the front clip is off. i can't wait a year for stainless.
hey mister
North Coast
Marty
I see you already got your headers in.
I put on a set of Summit's stainless with 3" collector.
I wrapped them with the fiberglass header tape before install.
I did use an inexpensive gasket and have had a slight leak, but when I pull the motor this summer to replace sesls and gaskets, I will get good gaskets.
Other than that, no problem.
I did have to fabricate a p/s pump bracket because original manifolds are 2+" thick at the bolt locations and headers are only 3/8" thick flange for mounting.
I do suggest a Stage8 header bolt kit. It keeps the bolts from backing out.
Well worth the money.
Djon23
