Stewzer55's Oldsmobile Station Wagon
Stewzer55
Ohio
Stew
R30
Here's mine:
VIN: 1G3BP8378NW303849
Yours is a later build date too, interesting.
RetroC10Sport
Green Bastard Parts Unknown
Jay
pontiac aztek
Report for..
1G3BP8378NW303849
Vehicle:
CUSTOM CRUISER STA WAG
Year:
1992
Build Date:
1992-04-10
Found 4,347 vehicles matching that year and model in our database.
RPO Description Matches
UB7 CLUSTER,INSTRUMENT,TEMP,VOLTS,TRIP ODOM,TACH,DR INFO CTR INCLUDES WSWA JAR,LOW ENG OIL LEVEL,LOW COOL,LOW FUEL IND TRIP ODOM(UB7) 3,694
UM6 RADIO,AM/FM STEREO,CASSETTE,ETR,INCLUDES CLOCK STEREO CASSETTE(UM6) 2,394
UQ1 RADIO,PROVISIONS FOR STEREO STEREO RDO PR0VISIONS(UQ1) 4,347
UQ5 SPEAKER SYSTEM,4,DUAL FRONT DOOR MOUNTED,DUAL EXTENDED RANGE QUARTER MOUNTED 4 SPKR SYS(UQ5) 4,307
U38 WARNING,LOW COOLANT CLNT WRNG(U38) 3,694
U75 ANTENNA,POWER(CHROME) PWR ANT(EXPORT)(U75) 3,694
VH9 ENVELOPE,OWNER INFORMATION MANUAL OWNER INFO MAN ENV(VH9) 3,975
VK3 LICENSE PLATE,FRONT MOUNTING PACKAGE FRT LIC PLT MTG PKG(VK3) 4,318
V08 COOLING SYSTEM,HEAVY DUTY HVY DUTY CLG(V08) 2,257
V73 VEHICLE STATEMENT - US/CANADA US/CANADA VEHICLE STATEMENT(V73) 4,347
V92 TRAILER PROVISIONS TRLR PROVISIONS(V92) 2,257
WRN PLANT CODE - WILLOW RUN, MI, USA 4,347
1SC PACKAGE-OPTION 03 (1SC) 1,627
1SZ PACKAGE OPTION- (1SZ) 4,344
20B TRIM COMBINATION,CLOTH,VERY DARK SAPPHIRE (20B) 1,420
20I INTERIOR TRIM,VERY DARK SAPPHIRE (20I) 2,730
209 SEAT BELT COLOR,VERY DARK SAPPHIRE (209) 2,730
28U EXTERIOR COLOR,PRIMARY,NAVY BLUE MET (28U) 707
6TL COMPONENT-COMPUTER SELECTED SUSPENSION SUSP(6TL) 2,987
7TL COMPONET-COMPUTER SELECTED SUSPENSION SUSP(7TL) 2,987
8RN COMPONET-COMPUTER SELECTED SUSPENSION SUSP(8RN) 4,347
9RN COMPONET-COMPUTER SELECTED SUSPENSION SUSP(9RN) 4,347
AA7 WINDOW,ELECTRIC OPERATED,QUICK OPENING QUICK OPG ELEC WDO(AA7) 4,307
AG1 ADJUSTER FRT ST POWER, MULTI-DIRECTIONAL, DRIVER MULTI-DIRECTIONAL PWR D/SEAT ADJR(AG1) 4,307
AG2 ADJUSTER,SEAT,6-WAY POWER,SPLIT BENCH,PASSENGER 6-WAY PWR P/SEAT ADJR(AG2) 3,694
AJ3 RESTRAINT SYSTEM,FRONT SEAT INFLATABLE DRIVER SI INFL RST SYS(AJ3) 4,347
AM6 SEAT,FRONT SPLIT,3 PASSENGER WITH CENTER ARMREST FRT SPLIT ST(AM6) 4,347
AU0 LOCK CONTROL,REMOTE ENTRY(KEYLESS ENTRY SYSTEM)(USED WITH TROFEO SPORT COUPE WL3) REMOTE ENTRY LK CONT(AU0) 3,694
AU3 LOCK,SIDE DOOR,ELECTRIC ELEC S/D LK(AU3) 4,307
B34 COVERING,FLOOR MATS,FRONT,CARPETED INSERT(COLOR COORDINATED) FRT CPT INS FLR MATS(B34) 4,307
B37 COVERING,FLOOR MATS,FRONT AND REAR AUXILIARY FRT/RR AUX FLR MATS(B37) 4,307
B93 ORNAMENTATION,EXTERIOR,DOOR EDGE GUARD MOLDING DR EDGE GUARD MLDG(B93) 4,307
CD2 INDICATOR,WINDSHIELD WASHER FLUID LOW FLUID IND(CD2) 3,694
C49 DEFOGGER,REAR WINDOW,ELECTRIC ELEC RR WDO DEFG(C49) 3,566
C60 AIR CONDITIONER,FRONT,MANUAL CONTROLS A/C MAN CONT(C60) 2,280
C71 LAMP,INTERIOR,FRONT DOOR COURTESY FRT DR CTSY LP(C71) 3,694
DD1 MIRROR-I/S, R/V, TILT, DUAL READING LAMPS, COMPASS I/S TILT COMPASS MIR(DD1) 3,476
DL5 DECAL ROADSIDE SERVICE INFORMATION ROADSIDE SERVICE INFO DECAL(DL5) 4,344
DL8 MIRROR,OUTSIDE,RH AND LH REMOTE CONTROL,ELECTRIC,DEFOG ELEC R/CON HTD O/S MIR(DL8) 3,542
DV1 SUNSHADE WINDOW, ROOF RF SUNSHADE WDO(DV1) 856
D3X GEAR-SPEEDOMETER DRIVEN (25513049) (D3X) 2,257
D42 COVER,REAR COMPARTMENT SECURITY(SHADE) R/CMPT SECURITY SHADE(D42) 1,989
D64 MIRROR,INSIDE,RH VISOR VANITY,ILLUMINATED ILLUM S/S MIR(D64) 3,694
D74 MIRROR,INSIDE,LH VISOR VANITY,ILLUMINATED(USED WITH TROFEO SPORT COUPE WL3) ILLUM S/S MIR(D74) 3,694
D8I SENSOR-VEH SPD (10456089) (D8I) 2,257
E5Z ADAPTER - SPEEDO - DELETE 4,347
E9Z KEY - SPEEDO - DELETE 4,347
F40 SUSPENSION,HEAVY DUTY,FRONT AND REAR HVY DUTY SUSP(F40) 4,347
GU5 AXLE,REAR,3.23 RATIO 3.23R(GU5) 2,257
G67 LEVEL CONTROL,AUTO AIR(USED WITH GRAN TOURING PKG Y56) AUTO AIR LVL CONT(G67) 3,694
G80 AXLE,REAR,POSITRACTION,LIMITED SLIP POSITRACTION L/SLIP R/AXL(G80) 1,020
IQB TRIM,INTERIOR DESIGN (IQB) 2,132
JA2 BRAKE SYSTEM,HEAVY WEIGHT,DISC,DRUM HVY WT BRK SYS(JA2) 4,347
JM4 BRAKE SYSTEM,POWER FRONT DISC,REAR DRUM,ANTI-LOCK(CAST IRON) ANTILOCK DISC/DRUM BRK(JM4) 4,347
KC4 COOLING SYSTEM,ENGINE OIL ENG OIL CLG(KC4) 2,257
K34 CRUISE CONTROL,AUTOMATIC,ELECTRONIC CRCONT(K34) 4,307
K60 GENERATOR,100 AMPERE 100 AMP(K60) 4,347
L05 ENGINE,5.7L(5.7-7)GAS 8 CYLINDER 5.7-7(L05) 3,113
MD8 TRANSMISSION,AUTOMATIC 4-SPEED(THM700R4/4L60) 4-SPD A/TRANS(MD8) 4,347
MX0 TRANSMISSION,AUTOMATIC,OVERDRIVE(MERCHANDISING OPTION) A/TRANS PROVISIONS(MX0) 4,347
NA5 EMISSION SYSTEM,FEDERAL REQUIREMENTS FEDERAL EMIS(NA5) 4,335
N30 STEERING WHEEL(DELUXE) DELUXE STRG WHL(N30) 2,132
N40 STEERING,HYDRAULIC(NON-VARIABLE) NON-VARIABLE P/S(N40) 4,347
N65 WHEEL AND TIRE,SPACE SAVER SPARE,STEEL STEEL SPACE SAVER SPA(N65) 4,347
PH1 WHEEL,15X7(STEEL) STEEL WHL(PH1) 838
QEU TIRE ALL- P225/75R15/N WS2 R/PE ST TL ALS (9591637) TIRE(QEU) 4,347
R4Z TIRE BRAND ALL - GENERAL 4,347
R7A CONTROL - SALES ITEM NO. 26 4,344
Stewzer55
Ohio
Stew
R30
Four things that stick out:
28U Navy Blue Metallic 707 (No wonder it almost looks black)
DV1 Sunshade 856 Much more common on Buicks, no idea it was so rare
PH1 Steel Wheel 838 Once again, didn't know it was so rare.
G80 Positraction 1020 I thought this was more common among the tow pack wagons
But then again I had the only '94 S10 I've ever seen with a 3rd door...
heviarti
Emmett, Idaho
Buck
C25
383 Stroker
Keyless entry. Neato. Wish I had the key fob... Or a door lock key at all...
heviarti
Emmett, Idaho
Buck
C25
383 Stroker
Dealership stamp on the books is Portland... I wonder what fleet it was out of?
Chances are you can still get a Key Fob for it and program it to work if you have an ignition key. I'm not sure about the programming procedure for these models though. I know I've programmed a few for other vehicles. Some require dealership to do it. Maybe not with the age of this one.
RetroC10Sport
Jay
pontiac aztek
I think all you do is ground a wire somewhere or turn on the ignition and hit the door lock button a couple of times. But it will be in the owner's manual regardless.
Yep, it'll be something like that. Or cylce the ignition off and on 3 times, Lock button down, Turn Key off, Back on, Lock Button Up, Cycle Key 3 more times, stroke pecker 5 times, wait for headlights to flash 3 times, put thumb in your ass, then it's done.
RetroC10Sport
Jay
pontiac aztek
Or that if you're in to those things...:happy175:
Isn't that what it says in the Owner's Manual?
BTW, I thought of you when I seen this Meme on FB. I know you have to be the intventor of this one. You can delete it after you see it since it'll be off-topic for Vehicle thread. I cracked the hell up. I was going to tag you in it, but it was posted on one of my So Cali friends page.
RetroC10Sport
Jay
pontiac aztek
Nope..I didn't come up with that particular meme...haha
It has your terminology and everything. I know you like dem big blondes too. I just knew it had to be you.
southbaymiller
