Spring spacers
Obwonkonobe
AZ
Ethan
C10 custom deluxe
I've currently got a 78 c10 2wd sitting stock height on 31s. I rebuilt the front suspention with autozone stuff, all oem, nothing fancy at all, went with a buddy and off roaded it the other day and got hooked. I'm looking to just put a couple inches in the front, maybe 2 or 3. I read about these coil spring spacers, and found a good deal
https://www.summitracing.com/parts/sps-1706
Although im wondering what kindof rabbit hole im going down. I need to know how this will affect my steering angle, if I need to redo my alignment, how hard would that be? I also need to know if i need to reshim the upper control arms affer this, and if i need upper ball jointspacers so i don't kill them, thanks. Here are some pics
Rusty Nail
Rusty
350sbc
I'm not convinced that an OEM shock absorber will accommodate more than 2 bonus inches.
That makes me wonder about the brake lines.
It's a Chevrolet...I say go for it and see what happens. If it breaks, fix it so it won't. :33:
I bet you can get away with two inches and the truck will never know the difference.:boti:
yevgenievich
Place
Name
Year
Model
Size
Alignment and shock travel would get affected. Steering will also get some some effect but should stay within reasonable range
Obwonkonobe
AZ
Ethan
C10 custom deluxe
If I go with one at the spring and 2 at the fender, should I have it aligned? Or just send it
yevgenievich
Place
Name
Year
Model
Size
What do you mean by the 2 at the fender?
A set of one ton springs would give you a lift on the front as well. But it will depend on existing alignment spec. The camber change will be a positive. The amount of change depends on the geometry. There will also be some toe change but very minimal due to a relatively long tie rod length. You can calculate the change by measuring existing suspension geometry.
Rusty Nail
Rusty
350sbc
I bought new shocks very recently and the part number was the same for a 2 inch lift , as it is for stock.
Just sayin.
Obwonkonobe
AZ
Ethan
C10 custom deluxe
Just sayin.
Lol that's all I needed to hear. And I would go with new springs but the po put new springs in too, I see no reason to buy another new set when for 20 bucks I can do the same thing
Craig 85
Nashville, TN
454/TH-400/NP205
I used air Lift air bags on two of my C20 trucks to fit 33's with minor trimming. I then ran the air lines through the holes in the front plate. I only had to have it re-aligned. It gave me about 2" of lift. Summit has them for $88. They fit inside the springs.
https://www.airliftcompany.com/shop/81560/
Obwonkonobe
AZ
Ethan
C10 custom deluxe
I would but I'm going for cheap, plus if i do bags I'd put air on the truck too
yevgenievich
Place
Name
Year
Model
Size
Shocks work better when in designed work range. The main thing that stands out possibly more is the camber change. But that is easy to check with a regular angle meter when on level surface
Obwonkonobe
AZ
Ethan
C10 custom deluxe
What kindof angles should i be looking for?
yevgenievich
Place
Name
Year
Model
Size
For a truck suspension probably pretty close to 0°. Maybe just a bit negative around -0.3°.
I do not know the rate of camber change on the c10 relative to height, but it is not uncommon to have a 1° change in camber with 2" height difference
brentjo
