- Aug 29, 2010
- OKC, OK
- HotRod
- 85 K20 LWB
- Silverado
- 454 - Turbo 400 - 3.73
i prefer to do things once, and know whats wrong with it. bring the cylinder to TDC, install leakdown tester, apply shop air. you now know what is bad, and how bad it is. it will diagnose a lower end problem, a head gasket, and valve to seat seal all in one shot, and tell you how bad it is. i was always told to work smart not hard, if you're running a dry compression test, and a wet compression test, the leakdown tester is already ahead of the game. now throw in a leaky valve or a bown head gasketl, and you have more diagnostic work to do, where the leakdown tester is done.
You're right, but the average shade tree mechanic, or your average DIY guy doesn't have a leak down tester. But, I can usually be right, just from experience, a compression tester and vacuum guage. Sometimes I can even tell with just a vac guage and don't need the compresssion tester.
