- Dec 7, 2010
- Southeast PA
- Paw Paw
- Chevrolet Tahoe LT
- 5.3, 4WD
I am wondering how that insulator on the #3 plug broke though...
Hahahahaha!!!!!!
AGood **** guys, it really helps to have pals to help me through this **** and point me in the right direction.
Speaking of a good ****, I'll be right back.
Yah, I didn't have any with me, I will try that this weekend.Yep, I'd also do the PB Blaster as suggested in the hole. Its not going to get down in there right away, but it will seep in as you slowly remove it. Just work it in and out as mentioned slowly, and bring it out a hair more each time til you feel it give way if it ever does. Also, it probably would not hurt to do with while the motor is fairly warm The heat might help a bit.
Yah, that sucks, I know how ya feel, lmao. I am sitting here at my desk at work and I am still laughing and smiling and everybody is looking at me, but I can't help it, and it's all yinz guys fault.I guess if you got 2 people saying the same thing at the same time, if must be right. I'd a beat him, if i wasn't typing in more detail.
But it don't skeer me none. I can edit or delete his post if I wanna !!! I'd never do that though. How bout I just move it out to the off topic thread. I don't like sharing the glory of being right.
I'm gonna replace it tonight after work, and the battery, and I'll have more pics, write ups, and horror stories to share tomorrow, lol...It happens. Just hope it broke up small enough to exit the exhaust valve and not do any cylinder damage. Sometimes that happens when you are taking them out. The strain with the socket will crack an insulator that has been heated and cool a million times while installed. I've seen lots worse.
By the way, that broken plug, I put it on the #1 cyl so I can reach it easy and replace it, now that's some thinkin, aint it?
you're thinking wrong. i've never seen under 150 on a decent quality small block, regardless of how high or low the compression is, and the size of the cam.I'm thinking 90PSI is going to be good on a low compression 8.0- 8.5:1 motor. More importantly is if all cylinders are within 20% of each other. 65 is obviously a little low, but that could also be cuz the motor wasn't cranking good enough. The proper way to do a compression test is to pull all the plugs, then test each cylinder.
