- Sep 8, 2019
- Northern Wisconsin
- Taylor
- K10, K25
- 400(?), 350
So I have never replaced shear pins before but I bought a box of "MTD Shear pins" from farm and fleet and since its an MTD(I know) I am going to try to put them in. These are rather simple things right just a pin that has a designed break point that is low enough to protect the augers and the spider gear thing? Should I replace even the good ones? Cant be more than 10 years old. Its one of those cheap chinese dime dozen ones you toss if the engine dies which isnt unheard of.
I am gonna do a simple spray out of the carb, gas is already gone, , etc etc. But I haave looked for grease points and I havent seen many, i see one inside the thing on the setup but anyone know if there is something that could be hiding
And I need more traction with this thing. It likes to spin tires. Since it has tires, And self propelled, would liquid ballast for tire fill be enough or should I look for tire chains and also do they make them down that size. This snow blowerr is definitely a mid size unit comapred to some things I have seen in my hometown because Its not so wide but they have larger tires which I thought had chains but who can remember.
I was also gonna paint the chute with my graphite paint. well, the intake area and the chute to my ability I guess.
