- Sep 8, 2019
- Northern Wisconsin
- Taylor
- K10, K25
- 400(?), 350
I have a 77 buick electra. AC. Sat for a LONG time. The thing runs, surprisingly. But its gonna need some work. First and foremost, I am going to replace the carburetor. I know quadrajet fans will say their piece but unless a brand new one could be had out of the box(or rebuilt) for competitive prices that wont require internal adjusgments, I am going to go my route of edelbrock or holly or other brands. I have a quadrajet manifold adapter for a edelbrock already(should work if it works for sbc?) and the iron manifold appears fine, I wont remove it because its not leaking and its useable. This car was hobbled back to life by the first owner who i bought it from. Sat in a shed since 1988. The radiator leaks because washer fluid must have froze at the top of radiator, so I will need it repaired or replaced. Its not beefy by any means... thoughts?
Its gonna get all fluids, all hoses, tune up, gaskets on valve covers, belts, etc.
AC will stay in place for now but not touched.
Anyone have experience or relevant information that might be helpful? It appears lines at fuel pump are leaking, which I can fix.. but they are swollen... did someone use vacuum line for gas?????
If I replace carb, can the cruise control module and stuff be fitted on it? or would after market be better?
Alternator tests good atm, i will leave it in place. Water pump pushes well. Clutch fan will be replaced. Brake fluid leaks from rear, will address.
Motor sounds healthy and has an exhaust leak with a beautiful note.
heres some pics:
heres some pics:
