- Sep 8, 2019
- Northern Wisconsin
- Taylor
- K10, K25
- 400(?), 350
The radiator had washer fluid in top of the rad. I cant see the leak but it comes out the top, because it leaks down about an inch on its own.I made a mistake here. Your carb has a hot air choke so it’s an M4MC. I saw the black choke heater and looked no further at the steel tube going into it. It’s more like your thermostatic mechanism for an electric choke being integral to the carb rather than being divorced and sitting on the intake. I would actually prefer this over electric and divorced myself, but you can convert to electric if you so desire. They sell the kit but you’d be wise to wire it through an oil pressure safety switch so the choke doesn’t run away if you leave the key on for a little before starting and screw you up on a cold day. I’d also do it on a fused circuit, but if you do it to just a keyed hot, put an inline fuse in the circuit for extra safety.
Bruce gave a lot of good info. The main thing I’ll add is you car should have the emissions sticker which tells you what all accessories are supposed to be coming off the carb. Then you can discriminate between what you want to keep and what you want to delete. If it’s gone, Autozone has the diagrams. Yours should just be federal emissions for a ‘77 Buick 350.
I’d expect a turnaround of 5-10 business days. I think I waited a week for mine to get done so it was pretty quick. These boutique carb builders should stock a few BOP Q-Jets, but you already have the core so I wouldn’t pay more than you have to.
For the rad, I like the idea of the Champion all aluminum or saving the OEM one if it’s the brass/steel unit. If you have access to a good radiator shop, you can have it cored out and any leaks soldered. That service around my area is 50-100. Plastic tanked aftermarket rads are throwaway and replace after they bust IMO, but I don’t care for plastic very much. If you can see the leak, and it’s just one or two tubes where they meet the tanks, it’s no big deal to fix it and keep rolling.
Why would you prefer the hot-air choke to a electric? Im curious. what does it do for you
