Side window defrost add?
78C10BigTen
pennsylvannia
Ted
C10 BIG TEN
I think the dryer vent looks better.
The best part i see.... the hardees cup on the dash....(sorry carls jr.) damn now im hungry!!
86Apache
Banned
WV
Marvin
C10's ,K20
250 six, 350's
Hmm,, If you had a floor console I wouldn't think it would be too big a project to run ducting to the back window and defrost both it and the side windows the from the rear.
The trick would be to make the plumbing look decent and if there is enough airflow to pull it off. Booster fan?
Or maybe easier just to get an electric heater/blower behind the seat and plumb it from there?
You have my wheels spinning, I could do something like that and not permanently alter my mostly original truck.
usar17
PA
K20 Silverado
TBI350/700r4/NP208
Did the 88-94 dash setup have side defroster vents? I feel that style was still very similar to the 73-87 dash
Sent from my SM-G950U using Tapatalk
usar17
PA
K20 Silverado
TBI350/700r4/NP208
They appear to. Think I may need to go do some measuring at the junk yards
yevgenievich
Place
Name
Year
Model
Size
I have a 94 sitting in a drive way if you just need the width measured
usar17
PA
K20 Silverado
TBI350/700r4/NP208
I’d go with adapting the stock dash or @86Apache ’s idea. No offense to any nbs guys, but those other dashes are fugly.
If that 94 dash fits tho...you could easily redesign the main cluster/HVAC/radio area. It just a big rectangle lol
usar17
PA
K20 Silverado
TBI350/700r4/NP208
If you get the chance to please. I would assume the most important things are width and steering column placement. I measured from center of the column to the left. And across the top and bottom of the dash for max width available. Just out of curiosity I also measured the depth across the top.
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
Man, I don't know. That sure seems like a lot of hassle and expense that may not be needed. My setup works great, and it was free. You just have to make sure to get the inlet of the hose positioned correctly, so the windshield still gets some heat too.....
How often do you have to clean the lint outta your defrost hose?
yevgenievich
Place
Name
Year
Model
Size
94 dash
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
Call me crazy, but wouldn't you think it would be easier to figure out how to tap a couple of small hoses into the existing ductwork than trying engineer in an entire dashboard and instrument cluster that was never designed to fit the truck?
Looks like you're trying to kill a mosquito with a sledgehammer.
usar17
PA
K20 Silverado
TBI350/700r4/NP208
Big Chip I've been looking at stuff similar to that for a pot cheaper lol.
Blue Ox I completely agree. I need to see if there's even enough space to between the dash pad and substructure to run duct work to each end.
Big Chip
Michigan
Kevin
C35
They don't give airplane stuff away.
usar17
PA
K20 Silverado
TBI350/700r4/NP208
Can find cheaper automotive vents lol
minnesotajoe
