- Aug 3, 2010
- Usually not in Ohio
- Andy
- '77, '78, '79, '84, '88
- K5 thru K30
It rained all night and most of this morning here. I just went through the cab and can't find anywhere wet except for the flat side of the floor pan passenger side. That is almost always damp though because that soundproofing mat holds the moisture.
Sent from my SM-G950U using Tapatalk
It could be running under the carpet, then only getting wet where it pools. You can poke around under the dash, looking for traces of water leaking down the firewall and kick panel. Or you can pull up the carpet, close the doors and hose it down real well. It also helps to have the dash pad and glovebox removed.
