- Apr 11, 2017
- kansas
- Rick
- c20
READ POST 103 throughly. I can find you 100 more telling you where you should mount the pump. Told you how I did mine.Well i haven't gotten to there quite yet, i gotta crawl underneath to see where i have room and such. Plan on going out of the sender unit, i to the check valve immediately, and into the filter, which will be probabaly just sitting there. I was thinking of mouting the pump on the top of the truck frame rail, under the bed frame, right where the bolt for the old sender unit ground was, so it will be a straight 2in shot right to the old fuel line hookups, wouldn't have to modify much. So basically like my crappy little picture, but the pump down a bit, fist with the top of the tank.
Itll have only the height of the tank to pull fuel from. Which no matter how i do it, it will have to anyway, becase of the sender unit shape.
Thats my preliminary plan anyway, will have to crawl underneath and look at it closer, but i think that'll work. What you think?
Pump should be lower than fuel level if you don't believe me,maybe you'll believe summit and holley. I can get more if you need.
