Should i fix the TBI or go to carb? And what's this wire?
AyWoSch Motors
The Parts Guy
New Mexico
Ayden
K1500 Sierra
350ci V8
You can use your factory tbi wiring for your pump. I wouldn't use the check valve,you want the pump after the filter to keep crap out of your pump. At the front you are still going to need a bypass regulator like the holley I put up,for your return,so you don't dead head the pump. You could get away with a wix 30041 filter in front instead of the regulator.
So far, i have it hooked up with no regulator. I was going to, but guy at the parts store who i know pretty well said, these are low PSI pumps designed for carburtors, shouldn't need a regulator. Said he has one on his impala and so far its worked. Said if it seems to be getting to much, restrict the line a bit with a hose clamp or wire, itll slow.
Figired id try it like that for a while, and see if it works. If it doesn't, than ill buy a regulator and hook it up. Have a good spot up top on the intake, with a return already to be setup.
We'll see.
And im very learly of using any of the factory wiring, because of all the issues i was having with it. May hook to key on power, but most likey just an independent fused circuit with a toggle switch
AyWoSch Motors
The Parts Guy
New Mexico
Ayden
K1500 Sierra
350ci V8
;( I didnt see that line, I was just making sure.
and I see your logic on the fuel check valve, whats your part number of your pump again? I will do a deep dive and ensure it wouldnt be an issue. I understand the logic of the filter, ricko @Ricko1966 but thats a lot of resistance to get fuel to the pump let alone push it the rest of the way. it needs to be a high flo kind of thing, like a sock on a sending unit(which is new)
I would not restrict it much further since it is also pulling through a check valve, which shouldnt be too bad if the pump doesnt have one itself
No worries. Ill go get the box, thanks.
Also, the guy said like 2-8 varying pressure, a Rochester likes about 6 roughly, so a little restriction in flow might help it not be 8 ever, and be closer to the 6 needed on average
AyWoSch Motors
The Parts Guy
New Mexico
Ayden
K1500 Sierra
350ci V8
Box
And i was thinking right about there, or there abouts. Itll have maybe 12in of gravity to fight, and probably 24in of line total from bottom to tank to pump.
(Its a flatbed, so easy to access all of this )
wanderinthru
Mid Point Route 66
Shakey
81, 70, 75, 84, 89
K 10, C 30, K 20
Box
Looks good to me. I would definetly install some sort of shield between the rear tire and tank and all your new stuff.
AyWoSch Motors
The Parts Guy
New Mexico
Ayden
K1500 Sierra
350ci V8
Box
Actaully more like this...just the pump there, and have the other 2 loop around to the sender unit. A slightly longer piece. (Itscold nothing wants to bend)
AyWoSch Motors
The Parts Guy
New Mexico
Ayden
K1500 Sierra
350ci V8
Whys that, just to keep it a little more dry?
Could probably use a mud flap backwards as a wheel well.
wanderinthru
Mid Point Route 66
Shakey
81, 70, 75, 84, 89
K 10, C 30, K 20
Keep your tire from throwing stuff at it. Personally would weld in a piece of sheet metal so it ain't flopping around.
it doesnt appear to have a check valve internally so you should be good on that. And were you moving your plan to make it so it only has to lift then send or something?
AyWoSch Motors
The Parts Guy
New Mexico
Ayden
K1500 Sierra
350ci V8
Thanks for checking on that, good to know.
Sorry, wha was that second part?
More or less just wondering whatcha doin (or was this just a pic of someone elses to show what you planned to do?)
AyWoSch Motors
The Parts Guy
New Mexico
Ayden
K1500 Sierra
350ci V8
Well i haven't gotten to there quite yet, i gotta crawl underneath to see where i have room and such. Plan on going out of the sender unit, i to the check valve immediately, and into the filter, which will be probabaly just sitting there. I was thinking of mouting the pump on the top of the truck frame rail, under the bed frame, right where the bolt for the old sender unit ground was, so it will be a straight 2in shot right to the old fuel line hookups, wouldn't have to modify much. So basically like my crappy little picture, but the pump down a bit, fist with the top of the tank.
Itll have only the height of the tank to pull fuel from. Which no matter how i do it, it will have to anyway, becase of the sender unit shape.
Thats my preliminary plan anyway, will have to crawl underneath and look at it closer, but i think that'll work. What you think?
AWBLAIR
