AyWoSch Motors
The Parts Guy
- Nov 6, 2020
- New Mexico
- Ayden
- K1500 Sierra
- 350ci V8
So far, i have it hooked up with no regulator. I was going to, but guy at the parts store who i know pretty well said, these are low PSI pumps designed for carburtors, shouldn't need a regulator. Said he has one on his impala and so far its worked. Said if it seems to be getting to much, restrict the line a bit with a hose clamp or wire, itll slow.You can use your factory tbi wiring for your pump. I wouldn't use the check valve,you want the pump after the filter to keep crap out of your pump. At the front you are still going to need a bypass regulator like the holley I put up,for your return,so you don't dead head the pump. You could get away with a wix 30041 filter in front instead of the regulator.
Figired id try it like that for a while, and see if it works. If it doesn't, than ill buy a regulator and hook it up. Have a good spot up top on the intake, with a return already to be setup.
We'll see.
And im very learly of using any of the factory wiring, because of all the issues i was having with it. May hook to key on power, but most likey just an independent fused circuit with a toggle switch
