Proportioning Valve and Bleeding
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
Where did you get your proportioning valve and what was the part number????
Not sure who you are asking, but mine came from Amazon and was a PV2. Around 30 bux. I'd buy a used OE as a 1st choice if one can be found.
hack_man
MA
Tony
I got mine from a local GMC dealer in 2006 "just in case" the old one had a problem. Looks like this part is still available at not much different a price than I remember paying for it.
Raoul Ross
Wisconsin
Raoul
C10 Suburban
Inline Tube It was very reasonable and appeared well built. The PR100 is the P/N for front disk/rear drum and PR101 for Disk/Disk. Search for proportioning valve. It'll ask you Year/Make/Model.
Some things to think about before topping-off the MS reservoir. The reason fluid level drops is because the pads/shoes are wearing. Think of it as an indicator of how much they're wearing. Now think about replacing those pads/shoes and pushing the fluid back to the reservoir as you push the caliper pistons/wheel cylinders back in. Yup, big mess on the floor!
This was how I sold brake jobs when I worked the service station life many years ago. If I saw the fluid low, (as you're under the hood 'Checking the Oil Ma'am!') you could visually explain to the customer what was happening and at least get them to agree to an inspection. I never ripped anybody off and usually the customer was appreciative as I'd offer to do it for free. Obviously that was back when there were Full Service Stations but the same principal still applies today... If the fluid is low, there's a reason!
idahovette
Weiser Idaho
Perry
K20-K10
I drain the master cylinder before I do a brake job with a turkey baster or a Mighty Vac, clean it out as best as possible and refill with fresh brake fluid. I NEVER push the fluid back into the master. I always open the bleeder and push the fluid into a bottle. Close the bleeders, then push the brake pedal a couple of times and recheck fluid, then back to the bleeders and open to check for air. Gravity works
hack_man
MA
Tony
Cracking the bleeder so the fluid doesn't get pushed back into the m/c has the added benefit of keeping the bleeder unfrozen during every break job. As far as gravity bleeding, I'm a believer, I went nuts once trying to bleed my brakes with the 2 person pump method but it just wasn't working and my pedal was mushy. Someone suggested gravity bleed and bingo! it worked.
71Muscle
