Rear brake bleeding struggles
Chris64
San Diego
Yours shouldn't have a button. I'd buy a centering tool, unplug the harness from the brake warning light,unscrew the brake warning light. Look at the end of the warning light switch that little Plunger drops into a groove in the shuttle to turn the light off. You should be able to get the shuttle to center by pumping the brake pedal,then opening a front bleeder while holding pressure on the pedal,I've heard of people using a small screwdriver to move the shuttle to center. I've never tried. I believe the threads on the switch are 1/2 x 20 to improvise a centering tool I'd drill the end of a 1/2 x 20 bolt a stick a piece of a nail in the drilled hole. Look on line for a centering tool,a pic and it will make sense.
I think that's a button on the left (it pushes like a button). The plug is in there very tight. At this point I still haven't been able to remove it. This pic makes it look easy to access. The pic lies.
So Am I correct: I need to figure out how to unplug wire, unscrew it and then use a pick or something to recenter it and then use the holder tool to bleed everything?
I'll acquire a holder tool as that sounds like it's required.
That's not a button it's a rubber dust cap that seals the valve, don't eff with it,you can't get a new one.And I'd try centering the valve with the pedal first, pump it 3 or 4 times then push and hold while somebody opens right front bleeder. If that doesn't do it,then try centering the shuttle with a small screw driver. Yes you unplug the wire from the switch,unscrew the switch,screw in the centering tool and bleed the brakes.
Chris64
San Diego
Here's where I'm lost - If I can get it centered now, can I bleed the rear without the tool?
If you get it centered if no one touches the pedal again, you can vacuum bleed them. If you try to two man bleed them without the centering tool, I don't see you successfully doing it. As for gravity bleeding them IDK,that's a flip of the coin depending on whether you have residual pressure valves either in the master cylinder or combination valve,the standoff valve may prevent it also.
Chris64
San Diego
OK, nothing is easy.
I got my holder tool tonight so naturally I had to go out in the dark and give it a whirl.
The switch came out fine but the tool wouldn't fit. A line ran behind it that kept it from lining up with the threads so I had to whittle it down a little.
Before
After
and now it fit
You can see that tube that was blocking it above. I had to take pictures to see any of this.
So while it was off I stuck a test light tip and did some feeling around. It felt centered. I could feel a flat space in the middle and a 45~ degree ramp up to each side. I tried moving it and it didn't want to budge either way.
I was thinking, maybe it only moves under pressure and then moves back (who knows?)
Anyway, so back to vacuuming a rear line. No luck after about 5 minutes.
I guess my next step will be either the line out of this proportional valve or the junction about half way back.
Just thought I would post my latest and document my suffering ;). I'm kidding. This stuff can be fun and I've always dreaded bleeding brakes. When I get this fixed I will be very happy.
Before
After
and now it fit
Remove the bleeders make sure thay are clear and you can blow through them.Then try 2 man bleeding it now that you have the centering tool in place.
Chris64
San Diego
Just to put closure on this, I finally got the new rear hose and surprise - everything is clear and works properly! I may dissect the old hose just to see what the problem was. I'll probably replace the front lines as well.
One of the fittings stripped so that meant I needed to buy a flaring tool. So many new things. but now I have 4 braking wheels.
So based on this, should I be looking at replacing the proportional valve or the master cylinder (etc) or just the two front soft lines? The hard lines all seem fine.
evren
San Diego
evren
c30 Cab and Chassis
On my 73 C30, I just replaced everything. I first just tried to bleed them but same as you nothing would come out. Everything was rusted and dirty and after I took the drums off I realized it needed a complete rebuild. It looked like they had worn the shoes down to the rivets at some point which put groves into the drum. Then replaced the shoes without turning the drums so now the new shoes had groves as well. The brake adjusters were completely rusted and frozen and did not work. It was hell to get the drums off because the shoes were stuck in the groves and the adjuster did not work to back them off. The wheel cylinders were no good either. I was happy I dug into it and got it all done up right. It looked like there was stuff leaking, maybe from the wheel seal and axle. It was a lot of work but I feel a lot better now that the brakes are completely redone. I replaced all the rubber hoses and the master cylinder. One of the hard lines in the back stripped out so i had to bend a new one. When I redid the front, I just started from scratch again new, hoses, calipers, hubs, pads, everything. On the rear, I did that first before the front, they bled no problem without doing anything to the proportioning valve, after i rebuilt the brakes.
On my 78 C20, when I first got it the brakes would lock up from time to time. That was caused by the rubber hoses starting to collapse. Was not fun when it happened.
If you look on the old drum pic you can see the groves. I don't have a good pic of the old barke setup but it was clear it was a mess.
thefoxtango
