Power steering pump hydro boost
Bradsterk3500
Ontario
Brad
This is my first post. So I'm not sure if this is the right spot. I think my power steering pump is going. It's making a loud whiny sound. I have a hydro boost. Just curious how I get the pump out? I heard that they're separate from the tank. Any help is much appreciated
1990 v3500
SquareRoot
They're not all separate. I have both versions from 85. The remote is off a diesel. Have you verified it has the correct fluid level? Low fluid will make it squeal like a pig in Arkansas.
Bradsterk3500
Ontario
Brad
Yes fluid is topped up. A buddy just said maybe bleed the system in case air is in their the hydroboost systems are notorious for that.
Bradsterk3500
Ontario
Brad
Just letting you know. I replaced a small leaky hose from pump to box. Topped up fluid and my brakes and steering are back. But you're 100% correct. Low fluid and she skweels like a pig.
fjordanasi
