PrairieDrifter
- Dec 28, 2014
- North Dakota
- Mason
- Suburban k10, bonanza k10, c30 C&C, c10, gmc 1/2ton
- 350, 350, 350, 350, 350
Does the thing actually do much? It makes it a tight fit for the exhaust so I’m on the fence about removing it. If it doesn’t do much I’ll take it off for the exhaust clearance, the exhaust is right where I pretty much want it. I don’t want it any closer to the frame rail. So at this point the brace is in the way.
Maybe I can bend it away? Or maybe cut it at the end by the trans and modify the eye to sit the opposite way and then weld a sleeve on the outside?
