No one has a practical use for dually split rims anymore, right?
rt66paul
California
paul
1991 suburban
I am really surprised that in 2020 is even asking about this. I had some on a '69 longhorn pickup and could not find anyone to install tires on those rims - and that was 1975/76.
Dooley
North Coast
RW
V30
I dont plan to use split rims ever, but its not something anyone in their right mind or at least practical application use, is it?
If you were about 1000 miles closer I would take them off your hands if they are the "split ring" model.
It's the solid ring 2 piece that is most dangerous and I would not use them.
Galane
Idaho
Gregg
Sierra 3500
Before being drafted into the US Army (circa 1960), dad worked at a tire shop. There were a few circle marks in the ceiling from split rings. They had a special spot for airing those up, with a cage to flip down over them. Anyone caught inflating a split ring off a truck without using the cage was fired on the spot. I'd assume the same for the guys responsible for the ring marks on the ceiling, possibly on their way out the door to a hospital.
Trent holbrook
Ohio
Trent
Sierra grande
350 model k1500
Attach a board on tip to make a work step
these appear to be split rims?
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
The RH5 type is the failure prone one that became known as the "widow makers". The other locking ring types are perfectly safe AS LONG AS there's no heavy rust or cracks that could cause them to fail. They also need installed by someone that knows exactly what they are doing.
R5 is what I have
southbaymiller
