need help not sure where to post so here it goes
ice205
montana
lee
1985 chevy
suburban
ok first of all ...i have a 85 chevy suburban 350 lm1 goodwrench 4 bolt main motor .....runs great and so on, i took the smog pump of and plug the one vacuume line and pluged the 2 exhaust holes one on each side now it runs like crap ... no im not wanting to put it back on ... i have a rochester carb on it .. the vacuume line diagram would be fed standerd the motor is newwer then the original one (been replaced a couple yrs ago ) any info or pics would help ...thx
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
Put everything back on, and see if it helps. Contrary to what most say, the smog pump does not rob enough power to be noticeable, unless the pump is starting to freez. Can you give us the 3 letter code from thebdiagram? and I am assuming the line that you plugged was to the AIR diverter valve?
austinado16
Central Coast, CA
1990 w/307k miles on the clock
GMC V1500 Suburban SLE
5.7L TBI/4L60/3.42's
Welcome! Nice to have another Suburban onboard!
ice205
montana
lee
1985 chevy
suburban
im going to put a 12 inch lift with 44 s under it ... so here goes the thing ...the air pump goes to a valve the vavle has 3 lines one to the decal valve , and one to left side exhaust and one to the right ....now the fed code would be for emissions like xfa diagram .. so ill stick the other valve on and hook the lines back up .. i know it will be fine again .. so curios if the factory exhaust manifold would cause the problem the other valve name is the dvtr valve that comes off the pump then to the exhaust and one line to decel valve......who ever thought of useing this crap had to be an idiot ...dont need it but i dont feel like ripping every thing apart and redoing the intake and so on ....
Jims86
Patterson,Ca
5.7 TBI
If you dont need it, thats cool, and it should not have caused an issue. The easiest way to see whats going on is to at least hook the vac lines back up, and give her a whirl to see if the problem subsides or not.
Driver4r
Nebraska
Trevor
k10,c20
On a suburban???????:boxed::uhoh2::confused:
Your COG is gonna suck, but hey, its your ride. And i cant blame you, i was originally gonna do the same to my k10.
ice205
montana
lee
1985 chevy
suburban
ok i found out my problem .. my daughter decided to help and switched plug wires on me ....shes 4 yrs old .......lol ......
ice205
montana
lee
1985 chevy
suburban
and too ..driver 4 ....................i live here in montana .. so roads here would be better dirt ..insted of potholes every 4 feet......and 2 no bumper hieght law ..........also please refresh my brain....cog...? as for i dont remember or ive not heard of the term..thx
Driver4r
Nebraska
Trevor
k10,c20
Center Of Gravity.
ice205
montana
lee
1985 chevy
suburban
ok .....yeah 38s was a first thought ..........just depends on how things work out...
Driver4r
Nebraska
Trevor
k10,c20
38's ide go 10" lift. 12" springs will ride liek crap.
A Burb is roughly the same length as a longbed pickup. And lifted Burbs kick ass.
Well that makes sense then, lol.
Driver4r
Nebraska
Trevor
k10,c20
Bucket, just for you, ill post this here.
ice205
montana
lee
1985 chevy
suburban
i also want a 2-3 inch fender flares and a windshield visor with no lights for mine ........ but like ur burb
animal
Lee
c10 silverado
350ish
Just for him??? Hell Andy probably owns at LEAST 1 just like it.
brentjo
