My Mean 350
Irishman999
Safford Arizona
Jason
K-1500 High Sierra
High five for you, looks good. if you were to run a stock air cleaner I may just bust a nut. I am doing something similar with my build.
Sent from my ADR8995 using Tapatalk 2
lusktommy
Tuscola, TX
Tommy
5.7L (350ci)
Just got done placing an order for my 350
-Mallory 85 Series HEI Distributor
-Holley 4160 600CFM Carb (getting rid of that Eddy Performer 600)
-Mallory Spirl Core Plug Wires
all of my ignition is stock so that ignition and better carb should boost performance and im putting my Crane Energizer 274 cam back in, we will she what it runs like after all that, im thinking it will do good, still debating on what i need to do about that factory 10 bolt posi rear end, id rather pull it and sell it and make money off of it and put something stronger that will hold in the place of it, rather then tear it up and not make a profit off it. advise plz lol
lusktommy
Tuscola, TX
Tommy
5.7L (350ci)
i know someone that i can prolly get Eaton Posi unit that was used in a 1983 Camaro that had a stock 305 in it and the man didnt abuse it at all, he would prolly let me have it for a couple hundred bucks, i changed it out for him and put a Auburn Locker unit in for him cuz he dropped a 502 big block in it lol
The Camaro posi won't work since that 10 bolt would be the crappy little 7.5 ring gear.
lusktommy
Tuscola, TX
Tommy
5.7L (350ci)
damn alright what would be a cheap swap that would stand abuse?
You might be able to find a posi from a '71-'81 Camaro or an 80's Caprice cop car.
lusktommy
Tuscola, TX
Tommy
5.7L (350ci)
wouldnt those posi units be the same as the 10 bolt posi thats already in my truck or are they different?
Trucks always had the Gov-Loc that's known to fail, but from what I've seen, they were never in cars. Cars always had an actual posi type diff.
lusktommy
Tuscola, TX
Tommy
5.7L (350ci)
well thats something that i can check on and do some looking around on thanks :grd:
lusktommy
Tuscola, TX
Tommy
5.7L (350ci)
ok I talk to my girlfriends dad and he gave me a number to get ahold of a guy and he told me he had an old chevy truck rear end that was give to him but he doesnt anything about it, so i drove out there and looked at it its a 14 bolt didnt pull off the cover to see what kind it was but its all there and he will let me have it for $250 should i get it?
I wouldn't pay that for one. Now if it were a CUCV with 4.56's and a Detroit Locker, probably up to $500 since the locker alone is over $800 new. But there are 14b FF's to be had for $150 and I don't put a nickel of value into one if it has a G80 Locking Diff. Those suck and it means even if you want to add a lunchbox, you have to change the carrier. Now when those get a little scarce, you might pay up to $200, but especially for a buddy deal, I wouldn't pay over $150 for it.
lusktommy
Tuscola, TX
Tommy
5.7L (350ci)
found another one, the guy took a pic with the cover off and sent it to me what do you think
lusktommy
Tuscola, TX
Tommy
5.7L (350ci)
he just called me back its still under the truck but this guy is clueless about it he saids it a 3/4 ton chevy 4x4 pickup with a diesel motor...we are on our own on info on it....pretty good size rear end you ask me kinda big for a 3/4 ton isnt it
Yes it's big and it's good. That's a 14b 10.5in Full Float. Break that one, then I'll believe you have some horsepower and 650ft lbs of torque. But, you won't break it. It'll probably hold up to all you can throw at it and that's why wheelers and rock crawlers want them. They are also very common, and only people buying is those who want them for wheeling because it's not people buying one to replace their broken one. They don't break. That's why they are so common. The truck will rust away long before the 14FF goes bad. They may get a bit noisy and get a bit of slop in them and some picky people will rebuild them, but they don't break. I only know of 1 person that broke one and it was very extreme conditions and was probably wore the hell out with some major abuse miles on it.
Are you willing to switch to 8-lug wheels though?
joker04
