My Mean 350
the advertised duration is 302 duration at .050 is 246 and the valve lift at .050 is .50" lift not that low for a flat tappet cam i know there is bigger but wouldnt waist the money on any bigger id go roller if i went any bigger
So what you're saying, is .500 lift? Most cams are given lift specs in .000. I didn't think it was that high because I used to run a 305 duration, .510 cam and when I first built that motor, the OEM valve covers were just sitting on the heads with 2 bolts started to keep oil from running everywhere when I primed it, then when I started it up, I got dents in the valve covers from the lift being to high for OEM covers and had to drop everything and go buy tall covers before I could continue working on it.
lusktommy
Tuscola, TX
Tommy
5.7L (350ci)
what kinda rockers did you use? idk about that buddy i couldnt tell you i know what i bought and i know what the specs are on a 302 Crane Enerigizer Cam are so as far as the rockers hitting the valve cover they dont and havent. so i cant really explain that to ya maybe i just got lucky hell if i know.
IIRC, that motor was using OEM rockers. I might have had the 1:6 to 1 rockers by then, not positive, but seems to me it was still the OEM at that point.
Swims350
Logan WV
none
in some cases to cheat and look stock you can run some thick gaskets and get just enough clearance to give a stock look without tall covers. I personally love the tall covers anyways so I run em just for the heck of it.
lusktommy
Tuscola, TX
Tommy
5.7L (350ci)
well there is whats up i have a moroso thick rubber steel core valve cover gaskets
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
302 duration? That must suck for low end torque....not a truck anymore!
lusktommy
Tuscola, TX
Tommy
5.7L (350ci)
Honestly the low end is still very good and she still has very very quick response and quick rev. but lightweight internals do that for you haha
Jims86
Patterson,Ca
5.7 TBI
Didnt you say you have a 2500 stall converter?............................
Haha?
lusktommy
Tuscola, TX
Tommy
5.7L (350ci)
Haha?
i do now not then i didnt. the cam wasnt big enough. with the cam thats in it now i have a Boss Hog Outlaw Converter advertised 2800 stall which is a hair too much im thinking about dropping down to an 2400 stall
lusktommy
Tuscola, TX
Tommy
5.7L (350ci)
honestly i just go by what the Camshaft Manufacture recommended to go with, because im not that experienced in using stall converters so advice and recs on what i need to use im always open to, i dont think im too smart or know it all because i have so much to learn thats the main reason i joined to put what i have on here and see if im doing anything wrong or see if i need to improve something
I don't get it. If you have to turn the AC off when you come to a stop so the engine doesn't die, it has no low end grunt.
Heavy truck, high-winding motor, 700r4, tall gears... glad you're driving it and not me.
You plan on running it down the track with the current combo?
Jims86
Patterson,Ca
5.7 TBI
One of the biggest things you need to remember, is bigger, is not always better....unless you are talking cubic inches.
lusktommy
Tuscola, TX
Tommy
5.7L (350ci)
not a 700R any more im putting a TH350 short shaft that has been rebuilt to with stand up to 550hp and that constant abuse and im also gonna do a ring and pinion swap to a 3.73 i dont want anything lower geared in this truck. ive run across a 1983 C10 SWB last night and the guy was wanting $2000 grand and it has a brand new 454 bored to a 488 very mild cam and a few other things, so i decided it was a good truck to stick my 383 in when i finished so i wrote the guy a check and im going to go get it this evening and see what the 488 is putting out and its also got a 12 bolt posi with 4.11 in the rear
GOBR
Memphis
R10
Pull that cam out and put somethin smaller in it. Youll be happy you did.
Just cause it sounds badass dont mean it wont run like a dog.
burnt
