my 88 k1500, tons of pics
Swims350
Logan WV
none
yea I posted some Tb pics in my tb thread.
I wished I had taken more but it being hot and I was in a rush to try and get it done.
Yeah, I saw that too bro, the heat is a bitch to do write ups, you done a great job. I will be using this info in the future, believe me.
Swims350
Logan WV
none
Swims350
Logan WV
none
I got the tb bolted to the intake, everything hooked up except for the fuel in line and the IAC. I have to reset it and I'm going to spray cleaner then air down the fuel feed line to make sure it's clean. I also removed the fuel filter to put on the new one once everything is cleaned. I bolted to gas tank bracket onto the tank, bought new bolts, washers, lock washers, and nuts to bolt it up with, and installed the sending unit back in the tank. I did all that yesterday.
Today I only cut the 7 crushed wires, removed the bad section and wired in new wire to reconnect them. This was caused by the last idiot who dropped the tank, samiched the wires between the tank bracket and the frame, crushed everyone of them. I'm shocked they never grounded out or that the things even worked.
I'm really hoping this weekend to get some new oil and fresh gas, and fire it back up to check it out.
Nice job Chris. :)
Swims350
Logan WV
none
brakes are bled, toe is set, truck still runs, truck is washed lol.
driver's side door handle inside took a poop yesterday.
radiator leaks.
Swims350
Logan WV
none
forget I mentioned anything about this piece a crap.
brakes aint right, prop valve has air trapped or something, if you bleed the same rear wheel more then a couple times in a row the fluid barely comes out, and the pedal feels hard and works good without the truck running, but when the truck is running the pedal goes like an inch from the floor, and if you keep pressure on it or shove it harder it'll completely drop and trip the light.
The heater hose nipple is leaking, if I fix it then I have to change the hose. i got a 5/8 on it as it should be and it won't fit over the nipple. it fits over the heater core nupple fine. This thing is just getting on my last nerve.
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
And all this has happened while it was down for the great work you have been doing? Sounds to me like somebody has been messing with Yo **** Bro!
Swims350
Logan WV
none
the heater hose was my fault, installed new hoses and it's tight, I forced and twisted a bit much.
the brakes tho have no clue. it;s giving my fits on them. I even started a new thread in the brake section for help on them.
The 2 heater hoses are different diameters aren't they? You mix them up?
Dude, I had the same exact problem with my 89 GMT400. Brakes were never right. I did the same exact things you did, all new brakes all around, M/C, yanked the anitloc crap. I had a problem with that proportioning valve and the light going on and off and a ****** pedal, I never could figure it out.
I HATE WORKING ON BRAKE SYSTEMS.
I'm with ya, John. I hate working on brakes!! just a simple rotor and pad swap is fine but when it comes to bleeding the system or working on drum brakes I'd rather pay someone to do it to be honest :lol:
Swims350
Logan WV
none
nope didn't mix them up, the nipple on the firewall for th eone going to the block is 3/4 the nipple in the block is 3/4. the nipple on the rad. aint sure, but the firewall has a 5/8 one for th eother.
I need to measure it.
I think on mine one is 5/8 and one is 3/4 on the heater core nipples. Not a hundred percent on that but I replaced the 5/8 line last winter and I know for sure the other one is bigger.
Swims350
Logan WV
none
yea almost every gm I ever worked on is that way one 5/8 one 3/4 same as mine.
Swims350
Logan WV
none
I actually did something to this heap today...
I tinted the DS window.
Well actually I removed it from the door, cleaned it, tinted it, then reinstalled it. All in like 2 hrs or less.
Not bad for a 1 person job, I got a tear in it putting it back in and got one dirt spec in it.
I'll have to get pics tomorrow, gonna try and do the other one after we look at a house for sale.
Blazah
