My 454 build
Are the pistons oversize at all? .030 over? Standard? If they're oversize I'd save them too. I've done some pretty good very cheap budget builds in the past. I've had buddies blow engines similar to this and trash the whole short block. Their pistons were TRW Forged .030 over and 1 piston was trashed, a couple rods etc. I'd buy 1 .030 over TRW Forged piston about $20 then bore a standard block .030 over and their pistons pressed on my reconned rods, then buy a re ring kit, timing set and oil pump. Use my good heads off another engine, install new valve seals and my good race cam with a new set of lifters and I had a brand new engine for pretty damn cheap. Amazes me that people toss pistons like they do. I can see if it were a race engine with NOS or Boost, but basically stock engines don't heat pistons like race motors do, and they just don't wear much at all. It's the rings that ride in the cylinders and wear. A little piston skirt wear doesn't make a piston unusable with a new set of rings. I have even used good used race pistons that had about 10-15 passes on them. They were still perfect and made a good street/strip engine that had a big cam and no NOS.
rumblebox
Victoria, TX
Carlton
The pistons are standard flat tops, but the full set i have are standard dishes. I'll probably sell them since hypereutectic domes are still pretty cheap.
Sent from my LG-H910 using Tapatalk
rumblebox
Victoria, TX
Carlton
So i took the crank out of the RV engine, and the thrust bearing was worn down to the welds and ate away most of the crank thrust surface. So that crank is trash too.
Turbo 400's are known to eat up crank thrusts. Whoever got that transmission, you need to let them know that transmission pump needs a fix. I forget exactly what the fix is, but there is a fix for that problem. It has to do with drilling a hole bigger in the pump IIRC.
rumblebox
Victoria, TX
Carlton
It's long gone. The motor had been sitting around in a shop for like 10 years.
rumblebox
Victoria, TX
Carlton
But at least i have a good block and rods, and i sold the 236 heads for like $120.
The 236 heads are the Piss Nut port heads right? Aka Peanut Ports.
I wish I could afford some older 396 or even older 427 or 454 heads. It's hard to get excited with this 454 I have when it's got piss port heads on it. I'd put a mild cam in it and a nice intake and let it eat.
rumblebox
Victoria, TX
Carlton
They have a lot of meat to work with.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Actually they don't it looks like it but to open them up to a standard oval port you would be threw the port. The peanut ports were cast different. Take an oval and a peanut and look at the combustion chamber side of the head at the intake ports.
4WDKC
Southern Florida
Kacy
How are you wanting to build it?
rumblebox
Victoria, TX
Carlton
Ok so now I'm just going to buy an existing 496 i found, since i dont have enough useable parts from these 2 engines.
I'm going to pull it apart and mic everything just to be safe and to know what I'm actually working with. I do know it has 049 heads.
Do you mean 396?
jlyon1006
