Here's something else to think about. When you tag a valve it's usualy an exhaust valve,because the piston is chasing the exhaust valve shut. The intakes are opening as the piston is moving away from them. I'd takethat engine apart and investigate. At the least I'd see if all the pistons are parking at the same height and pull the rockers on the low cylinders and manually open the valves feeling for binding opening and watching for binding closing., and usually a bent valve will park at a different installed height.
